Alemite Grease Fitting
  • bselph
    • Jun 2009
    • 311
    I am looking for a fitting. This one has threads that are 1/8" from the end to the base of the hex. The place where it goes has some stripped threads and I need one that has about 3/16" long threads. Hopefully it will reach some good threads deeper in the hole. Does anyone know of a source?
    Bob Selph
    1933VC/1934LT Sidecar
    1940 Sport Scout
    AMCA#15215
  • Jim
    • Sep 2001
    • 789
    How about using a short piece of pipe? In other words, make your own; use a small pipe to screw in, and then screw the fitting into that. Of course... it would have to be super short.
    Jim
    AMCA #6520
    • len dowe
      • Oct 2002
      • 520
      Bob,
      I don't know if this would work with what you have but why not weld it closed and tap it.
      Len.
      AMCA #765
      • Tommo
        • Sep 2001
        • 1320
        I think I can help you.
        Let me look and I'll get back to you.
        1929 J/JD front brake plate has an extension that the alemite nipple screws into and I may have a spare or two of them.
        You'll be using a genuine HD period part.
        Peter Thomson, a.k.a. Tommo
        A.M.C.A. # 2777
        • bselph
          • Jun 2009
          • 311
          THANKS! Bob
          Bob Selph
          1940 Sport Scout
          AMCA#15215
