1936 VLH Oil Pump "spring, ball and check valve" question.
  • Jim
    • Sep 2001
    • 789
    Today I had taken my oil pump off my '36 VLH. The Ball, spring and little plunger fell out (yes, I found them right away). On assembly I am thinking that the Ball drops in the hole on the oil pump, Then the spring, Then the plunger with the shaft of the plunger inside the spring so the wider "flat spot" sits against the engine. Isn't that the correct way to put it back together? Just double checking!!
    Jim
    AMCA #6520
    Dear Jim, yes that's the way. I usually replace the ball and spring on principle, and lap in the ball seat with a ball soldered to a piece of copper tubing.
    • Jim
      • Sep 2001
      • 789
      Thanks Steve!!
      Jim
      AMCA #6520
