throttle cable replacement help, please
  • L. A.
    I'm replacing my throttle cable...last one kinked somehow, just about 6 " above the carb...
    The housing's fine, so I thought I'd just replace the cable itself.
    My question is: Is lithium or simply WD-40 OK to use to lube it up before inserting it into the housing, or is there something else I should use?
    I'm gonna try and do this without removing the housing...but maybe this shortcut's not a wise move???
    'Preciate any input...
  • Jim M
    A light coat of oil is all you need. Lithium is too thick and will attract and retain dirt. WD-40 is not a lubricant but was intended to be a water drying compund for electronic parts. I've been using oil for years trouble free.
    Jim
    • L. A.
      On the road again................
      Thanks to all who replied...worked out great...easy fix.
