Engine compression
  • sean clark
    • Mar 2013
    • 11
    Engine compression
    Does anybody know what the compression should be for a "45" flathead.I have 70# and 75#,this seems low to me.I always thought 100# was the minimum.Any answers would be appreciated,Thanks
    • 4784
    Depending on which heads are on it, the altitude where you took it, and the method you used the numbers can vary greatly. 75 on a 45 isn't bad, and 100 is very hard to find on one...
      • 2030
      Normally you turn a motor about 8-9 revs at canking speed to check compression--good luck doing that with a kicker
      • sean clark
        • Mar 2013
        • 11
        thank you for your help.This will help me alot.
