30v valve spring installation problem
  • hoghead
    • Aug 2012
    • 19
    If I loosen the cylinders to reinstall the valve springs then I can't tighten the one cylinder stud nut.
    Does anyone have any solutions or suggestions?
  • diesel55
    • Jul 2011
    • 262
    make sure all tappet screws are ajusted in down position. tighten base nuts than ajust tappets
    • Sargehere
      Member since 1972
      • Jul 2006
      • 971
      I don't quite understand your question. Are you having a problem reaching one cylinder base nut? If that's the case, you will need this:
      It's a common tool sold at auto parts stores, I believe as an auto clutch bell-housing wrench: 9/16" on one end, 5/8" on the other.
      Gerry Lyons #607
      http://www.37ul.com/
      • hoghead
        • Aug 2012
        • 19
        Thanks for the input. I just heated an old wrench and bent it. Works fine.
        • Sargehere
          Member since 1972
          • Jul 2006
          • 971
          That's great! You're welcome.
          Gerry Lyons #607
          • Jim
            • Sep 2001
            • 789
            We always called those "Starter Wrenches".
            Jim
            AMCA #6520
