I have a set of cylinders that the top head gasket area is pitted and would like to mill this flat again but need to know how much can I safetly take off without causeing any problems. Also I am looking for a lifter block puller for this, understand that the UL's have to have a special puller. v-twin sells them but has been on back order for quite awhile now. Thank you for help help
46 UL Badly pitted cylinder head gasket surface
I've already taken an 8" flat stone over the surface and can see how bad the pits are. The pits are even worse between the cylinder bore and valve area, what I need to know is how much I can take off. I know that with how low the stock compression is at and how much less its going to be if I leave it this way. I own a V-Twin machine shop so any maching that needs done is no problem. These pitts are not minor...
thanks for the reply Larry
Can you post a picture?
There are some anaerobic filler products out there that can fill pits in a gasket area. Pyro Putty is one that comes to mind. But there are some better ones as well from, I think, Loctite. I can look up some names tomorrow at the shop. Not ideal vs. machining, but sometimes there is not enough left to machine or the part is irreplaceable. The high-temp epoxies can extend the life of a part that may otherwise have none left...
Cheers,
Sirhr
Would it be to hard to fill the pitting with silver solder and then deck them? Just a thought. Bob LLast edited by Robert Luland; 09-03-2012, 05:28 PM.
Bob:
Good thought, but those are aluminum heads. Silver wouldn't stick and the heat would be enough to warp them if you tried to weld.
We've done some interesting repairs to D-series Phantom III heads using sleeves, machined and pinned-in fillers, etc. Sometimes you can also use the Irontite Plugs that I did some photos of in the "I hate Helicoils" piece I did last spring. Irontite makes aluminum tapered plugs as well. But you need some 'depth' to use them. And I don't think you have enough room to use pins... but that's why I was asking about pictures.
Best case is, as the OP says, machine the flange/sealing area. It raises the compression some, but on a UL (low compression engine) there is plenty of room to raise a bit of compression. There 'should' be a spec for how much can be milled off safely, which is what the OP is asking for. If the pits are deeper than that and extend far enough to prevent a gasket sealing... he has paperweights.
I'll be interested to see what they look like!
Cheers,
Sirhr
Go back and read the original post. Cylinders, not heads, therefore cast iron!Good thought, but those are aluminum heads. Silver wouldn't stick and the heat would be enough to warp them if you tried to weld.
Bob's solution is a possibility.Robbie Knight Amca #2736
Sirhr, you understand exactly what I am after but, its not the head, head is in great shape. Its the top of the cylinder surface I am talking about. Also, the heads are cast iron not aluminum. will add some pics tomarrow when I am at the shop. I can figure all this out my self but would have to put just about the whole motor together to see what clearances I have to work with, was just hopeing that someone has been through this and could save me some time.
Thanks, Bob and Sirhr any help is always appreciated.
Rub: Thanks for pointing that out. I read Cylinders and Head Gaskets in the same line... and the visual that popped into my head was all wrong! My mistake... sorry!
On cast iron... possible, but you have to be very careful! If you overheat the cast iron, you can get a crack (likely a pair of cracks) at the "heat joint." But silver solder will stick nicely and if you use a low-enough melting alloy and are careful with heat, no problem! So Bob's solution is definitely one with potential. But make sure the welder knows his stuff! I know people re-weld fins and repair these cylinders all the time, so I am betting that it would be no problem.
As an aside, we try and avoid cast-iron welding (or silver-soldering) at almost all cost. Too much risk. But when we do have it done, we use a company in Oh called Columbus ColWeld. They will strip a part and then heat it up in a furnace to high black/low red temperature. Then weld it in an inert gas environment. The part is then cooled down over 24 - 48 hours, depending on the size, and remachined to true. Not cheap, but sometimes the only alternative. Once the parts are welded by some skeeziks with a stick and, as a result, are all cracked and contaminated... part is basically ruined. But done right, cast iron can be saved.
If you ever need to call Columbus ColWeld, ask for Maynard Stumph. Great guy and lavishes a lot of care on vintage parts.
Back before new Ghost cylinder blocks were available (at $9K each), we used to fix eroded/thin/weeping blocks by milling out the bad area with a thin flange, then by pinning in new plates to restore thin/rusted through areas. We would then soft-solder the joint. This was only at water jackets, so low temperature. Nothing near combustion areas. And it was only intended to be a 'temporary' repair until new blocks were available. Yet some of those blocks are still in service more than 30 years later. But we don't do those sorts of repairs any more. Again, too much risk (and time and labor) when new parts are available.
The good news with the UL cylinders is that if you don't solder, you can almost certainly mill enough off the top to clean up the damage and then add a spacer plate at the bottom of the cylinder to restore the height. That way you can maintain both compression and the pushrod lengths, etc. Even if you go a bit below 'factory' minimum, the factory set those minimums with the idea that once the minimum was reached, you would bin the part and get a new one from the shelf. There is probably some 'material to spare.' Remember that few of these old car/bike companies built vehicles with ANY concept that we would be cherishing them and restoring them and riding them 65 years later!
Depending on how much gets cut from the top of the cylinder jugs, valve seats may have to be recut and that could be a concern... How deep you can go with the seat??? That may be your limiting factor for depth. Just thinking out loud on that one...
Cheers,
Sirhr
PS. If you call Dave "Rat" Sherk at Harbor Vintage, he almost certainly has a number. And Steve Slocombe who is active on this forum will also probably have some outstanding experience here. You can find him easily on the forum. I'd be surprised if he didn't respond by morning... being in the UK, he is likely kipping some Z's right now.Last edited by sirhrmechanic; 09-03-2012, 06:35 PM.
What Kerry says is right on. The area between the valves and bore can also be "relieved". This would clean up the pitted area, and provide better flow. Lightly grind the path between the valves and bore. This will lower the compression slightly, but will improve power at higher RPMs. Just make sure you stay away from the gasket area. Put a gasket on and scribe around it first. I'm sure a search will turn up "how tos" on relieving.AMCA 6295
I set cylinder up in the mill and indicated it, .015 will clean up the gasket surface and .020 will clean up the whole top. It isnt going to do any thing with the valve seats but am concernd about piston height, but then I guess I could always make up for that at the base gasket. Still can anyone tell me if its safe to take that much off the cylinder top?
Taking .015-.020 off the cylinder will not affect it at all. The difference in compression will be small, like about 1/4 of a point! The only thing to look at is top of piston to head clearance in the squish area. All the racing flatheads popped the pistons up and had a pocket relieved in the heads for better squish. If you needed more clearance that is where to get it!
RobbieRobbie Knight Amca #2736
