speedo cable - parkerized?
  • flthead
    need a speedo cable for my 37 ulh , any body no whos making the after market type , need 1 with parkerized housing ,not cadium plated. book says it should be parkerized . i do my own parkerizing but cant do over cadium ,cant sandblast it off either . any suggestions
  • Erdos
    Strip the cad with Muriatic Acid (the stuff you clean cement with) and then parkerize. I do it all the time it works like a charm. Be careful to do it outdoors as the fumes are toxic.
    • flthead
      it will strip cadium off bolts to i guess? thanks
      • B. Rodencal
        DANGER!
        Poor advise! The By-product of Cad and Muratic acid is Cyanyde gas! It's a good way to take the last ride! FatDog
        • flthead
          0k ,anyother ideas?
          • Erdos
            If you want you can send me the cable and I'll strip it for you. Or I'm sure a plating shop can handle it.
