47 UL engine sprocket shaft nut removal
  • Martin Pettingell
    • Mar 2012
    • 88
    Hi,
    I am in the proces of removing the transmission from my 47 UL for a thorough overhaul. At present i have been unable to remove the engine sprocket shaft nut.
    The manual suggest a special tool that i dont have and Palmer's book suggests locking the chain / sprocket with a piece of wood to prevent movement while trying to release the nut.
    This hasnt worked - i cant seem to lock it down enough to avoid some movement and the nut wont budge.
    Is there a simple trick here to get the nut off or do i need to source the proper tool ? If i need the proper tool any idea who might carry them - i'm in the UK
    Martin
  • pete reeves
    • Nov 2001
    • 245
    Martin.
    I would use an air impact wrench (Anti clockwise) the nut should fly off.
    Pete Reeves 860 also from the uk
      • 4791
      If you don't have an impact use a breaker bar and the correct socket size. Put the breaker bar on and hold it against the engines compression. Give the handle a good whack with a mallet of any sort, preferably a dead blow type, repeat if necessary.
      The nut will come off. I've never had one not come off in 40 years!
      Robbie
      • pete reeves
        • Nov 2001
        • 245
        If I’m honest that’s the way I would do it if I did not have an impact wrench readily at hand. I was worried that suggesting using a bar and mallet would invite criticism.
        Pete Reeves 860
        • Chuck#1848
          • Oct 2004
          • 920
          That is the way I do it breaker bar,correct socket and dead blow hammer work's every time
          Chuck
          AMCA Member#1848
          • Martin Pettingell
            • Mar 2012
            • 88
            Thanks for the help guys - i dont have access to an air impact wrench but have the break bar and mallet - i'll give it a go.
            Martin
            • harleytoprock
              • Apr 2003
              • 374
              If someone has used red loctite when the nut was tighten , the nut will have to be heated to 500 degrees before the loctite lets go. Something wedged between chain and sprocket should pevent the crank from turning. In my youth I have used rags. There is a cheap delrin stepped block tool that works good. The wedge should be placed top,against sprocket and chain, so that the couterclockwise movement makes it wedge tighter. Good Luck?
              • Martin Pettingell
                • Mar 2012
                • 88
                Grateful for the feed back. The job is done now.
                After chewing my way through a few bits of wood i used an old 45 sprocket set between the chain and clutch sprocket to lock the crank down a bit more and it did the trick in combination with the socket and brake bar. Just another tip i guess.
                Thanks again everybody.
                Martin
