tank repair
  • johnnyfire
    senior member
    • Dec 2005
    • 100
    tank repair
    Aghhhhhhhh
  • sirhrmechanic
    Vigilis
    • Dec 2010
    • 1147
    Assume this was your reaction after using a match to look into the tank?
    More info... all may not be lost.
    Cheers,
    Sirhr
    • denismccarthy
      • Jan 2012
      • 125
      Johnny,
      I have a very good metal fabricator in Canada that can repair or build you a new tank. He's not cheap though. Let me know if you need his contact info.
      Take care
      Denis
      J.Denis McCarthy Come visit The Barber Vintage Motorsports Museum
      www.barbermuseum.org
      • johnnyfire
        senior member
        • Dec 2005
        • 100
        No,I didn't use a match to inspect the tank.As a firefighter I know better(or so you would think)ha,ha.I made the repair,but you should see what I did to the beautiful paint job!I have pics in my puter,but can't figure out how to add them to this,asks for a url ?????? The problem started with the brass fitting on the bottom of the expensive repop tank falling off.It was soldered on and thats what failed!The bottom of the fitting wasn;t flat and smooth,it had deep gauges and grooves in it.I don't think solder is meant to fill big gaps.
        • johnnyfire
          senior member
          • Dec 2005
          • 100
          Thanks,but I'll have to live with my repair.
