ul flywheels
  • markcoc
    • May 2009
    • 17
    ul flywheels
    I am debating on whether to use the stepped crankpin in my 39 Ul, or having flywheels machined to take the larger (41-84) crankpins. Are the stepped pins ok?
    Anyone have any comments, ideas, or experience with this, I would like to hear from you.
    Mark
    • 4791
    They have worked fine for 60+ years. Your results may vary!
    And be aware that Indian chief pins are even smaller!
    Robbie
    • koanes
      • Apr 2003
      • 656
      Nothing to be gained if your tapers are good. Crankpin bearing surface diameter is the same as the late pin.
      Kyle Oanes AMCA # 3046
