Engine mount dim.
  • David
    • Mar 2010
    • 11
    Engine mount dim.
    If someone has the engine mount dimensions for the VL and UL models would you please post them here. I have not had any luck getting this info from H-D, nor can I find any blueprints. Following dimensions are needed for both engines front mount bolt spacing, rear mount bolt spacing, Front bolts to rear bolts spacing, offset of bolt pattern to centerline of frame, and height of rear mount from front mount. If someone has prints showing these dimensions I would appreciate a copy if possible, or if somone has an empty correct frame and could take these dimensions from them. Thank You, David
