38 and up sidecar recoil strap
  • aumick10
    • Nov 2018
    • 464
    Just finished this recoil strap. Cut to length, punch in holes and good to go.
  • len dowe
    • Oct 2002
    • 503
    Amazing. Great work Mick.
    AMCA #765
    • micmac
      • Feb 2009
      • 466
      You sir are an artisan. Beautiful!
      Pete Cole AMCA #14441
      1947 Indian Chief
      • aumick10
        • Nov 2018
        • 464
        Thanks micmac. I needed some straps for my package truck, so i had to make everything from scratch. Got asked for sidecar straps, so here i am. Cheers
          • 8212
          I never ever encountered an intact real one, Mick,..
          So please let me ask: How do they work?
          Friction of the strap upon the bottom frame member?
          Thanks in advance,
          PS: My hack saw severe duty, so I saw the need!
          • aumick10
            • Nov 2018
            • 464
            Tom,
            The spring end bolts up to the front body support. the strap loops under the frame and clamps back up underneath the body. Dampens out the oscillations, apparently. Typical of the factory, a lot of different arrangements over the years. Up until about 1935, they had a rear assembly as well. I think they stopped using them when suspension was introduced to the sidecar wheel. Servicars had a similar setup on their boxes. Picture is of a package truck setup i made a while ago.
              • 4764
              This is an NOS one, also the double type for package truck front.
              • aumick10
                • Nov 2018
                • 464
                Rubone,
                was the double strap only used on the later package trucks?
                Cheers
                • panz4ever
                  • Mar 2009
                  • 197
                  Where did you source the check strap material?
                  • aumick10
                    • Nov 2018
                    • 464
                    I think it was Amazon or eBay. Took a while to get the right color and weave. Could only get 1/8: thick strap so had two thicknesses sewn together.
                    • len dowe
                      • Oct 2002
                      • 503
                      Thank you Mick. Looks great and I really appreciate the help.
                      This gallery has 1 photos.
                      AMCA #765
                      • aumick10
                        • Nov 2018
                        • 464
                        Your welcome Len, good luck with your build.
