Anyone know where to get 31470-66 starter cover bushing and 35098-66 trans cover bushing for 69 servicar?
bushings
Paps, thanks for the response. I know I am slow to get back but don't think I need them except to check end play of the starter shaft. Is there a dimension I should look for? All I am doing is replace the bendix gear. The old one looks like it crashed into the ring gear is why I ask. Thanks for your help.
Just the parts dimensions for end play. I've never seen a factory spec on end play Bushing flange thickness could be a problem if to thin. Can you post a pic or two of the trashed out bendix gear. It may not be trashed from end play issue. A visual for me will permit me to diagnose the damage.
Paps, I did replace the bushings. Got them local after I got the sizes. The small was o.e.m. Lucky? I ended up with .008 end play. Can't do a pic of old bendix but thinking the the marks on it came from the old owner having a goofy master link on the chain. Took the old one apart and the springs were all ground up and only 2 rollers doing any thing. It is a funny it work at all. Thanks for your input.
