Goulding rocket sidecar help
  • Goulding rocket sidecar help
    I’m looking at possibly buying a Goulding rocket sidecar to put on my dads 42 FL knuckle but need some help. It has no mounts so I’m looking to buy mounts or copy someone’s mounts or if someone has some blueprints. I can provide pics of the sidecar if needed. Any info would be much appreciated.
    did you get what you needed? I have two 50's rocket frames I may have parts for a rocket to harley connection. I too am scratching my head on hacking one to my 47 indian and having trouble seeing someones proper goulding -side connections.
      Thank you for the reply, I ended up going with a Harley sidecar.
        May still pickup the Goulding though, and would need all the mount connections and a correct wheel.
          send pics and I'll show you what I have figured out so far!
            These two pics are indian sidecar to 1947 indian chief connections
            This gallery has 1 photos.
                this is what I think is later (mid-40's to 50's) goulding sidecar frame connections front and mid (under seat post) I believe that will connect to 1947 Indian Chief - haven't figured out rear yet! my two frames are brake versions.
                  Those are some decent pictures, so all of those mounts are for Indian?
