Harley Side car ball joint removal
  • knuckcrazy
    • Feb 2010
    • 147
    Anyone have any tips or tricks on removing the Ball joint on a 43 Harley sidecar frame to replace the nuts.
    I have swaged screws out and fixing to get hateful with it.
    Bob
    • 4783
    The factory tool is pretty brutal. Use heat and a disposable bearing puller....
    • Buster
      • 384
      There is a good post on this with a lotdetailed of pictures on the Shovelhead Forum. Dont know how to post link but go to
      "Sidecar Issues & Questions"
      Then "Plumbers Joints" by Devils Halfacre. This post will come up on the second page in the sidecar section.
      Good luck with it.
      • knuckcrazy
        • Feb 2010
        • 147
        Thanks guys, I couldn't find the Shovelhead Forum but Robbie hinted at what I was already expecting, its gonna suck....
        I will get it just hoping for an easier way.
          • 8232
          I'd try a bodacious slap-hammer, Knuckcrazy!
          It doesn't look that permanent if its un-pinned.
          • ryan
            • Mar 2017
            • 610
            I used a slide hammer axle puller bolted to Robbie's, pictured, bearing puller tool after soaking it for a few days with a 1:1 ratio mixture of ATF and acetone. I also had to chain the sidecar frame to our huge corner post. I did try a propane torch the first time with the slide hammer, but failed. I guess I was lucky that it was the back one and my gondola nor wheel was on it was not
            Good luck, you will get it, even if you have to get mid evil on it.
            • bselph
              • Jun 2009
              • 311
              I had a friend make me a tool similar to the bearing puller. It however is 1 1/2“ thick solid steel. After weeks of soaking with Kroil and tapping on the joint, I put the tool on and used a 10# sledgehammer to bang the backside and it finally came out. As Ryan said I had to tie the frame to a column to keep it from sliding. Good luck.
              Bob Selph
              1933VC/1934LT Sidecar
              1940 Sport Scout
              AMCA#15215
              • Ric Bolduc
                AMCA Member since 2000
                • Feb 2012
                • 109
                I can help you out if you still need it. PM me are ricbolduc@outlook.com
                • maxglass
                  • Mar 2008
                  • 118
                  Ive used a ball joint fork or modified tie rod end remover.
                  Max
                  • panz4ever
                    • Mar 2009
                    • 198
                    Ball joint fork, heat and a pipe wrench with a 3 foot extension (installing new ball ends). Was a two-man operation.
                    • panz4ever
                      • Mar 2009
                      • 198
                      Frame ready to go to the paint shop once the new pieces are taped off. Installation required puttin the ball end part into the freezer for about an hour and heating the frame w/ a propane torch. Had to use allen head set screws to secure the part is only difference.
