Help to ID this frame
  • aumick10
    • Nov 2018
    • 465
    I went to look at a 20's sidecar a few days ago, but was unable to fully identify it.
    It looks like a mismatch of parts.
    I was able to find a tag on the body that said the body was a 30LT.
    However the frame didn't match the body. The leaf springs had been mounted on the lower cross bar, instead of the spring mounts.
    I suspect the frame is a package truck frame with the leaf springs mounted to fit the narrower sidecar body.
    I couldn't find a frame number in the usual location for a sidecar frame. Did the package trucks have their frame number in a different place.
    The springs look like they have lower "helper springs" that may be from a package truck.
    Any help in identifying the frame will be appreciated, as I would like to put the frame on a JD.
    Cheers,
    Mick
