Mounting a fender on 1960 Harley side car
  • sailfish
    • Sep 2010
    • 175
    I have a friend that is having trouble mounting the correct fender on his side car because of the step on the side car any help would be great the side car is a Harley .thanks
    • 4789
    Is the step original or homemade? Factory fenders and steps go right together. The fender has a loop on the front and matches a loop on the step with a pivot bolt.
    • sailfish
      • Sep 2010
      • 175
      Thanks for the help he says it’s a factor fender
        • 5955
        Is that Max Factor? :-)
          • 8239
          Watch out, Chris!
          The judges take cosmetics seriously.
            • 4789
            The fender is designed to release from the mounting at the axle area and pivot up to remove the tire. From '58 up the front brace was left off the sidecar fender. Where the rear brace and vertical brace come together the extension nut on the axle is the outer mount, the offset plate with stud is the inside mount. The offset plate bolts to the sidecar frame and the stud fits the slotted mount on the fender, when those mounting nuts are removed the fender is free to pivot forward on the step pivot.
            • sailfish
              • Sep 2010
              • 175
              Thank you for your time
