One more mechanical to hydraulic brake conversion question
  • Buster
    • 385
    Ok, same 1951 Harley LE sidecar with 1958-62 hydraulic brake conversion. My parts book shows no sleeve for spacing on axle between brake drum and backing plate. Is there an axle spacer for this or does it have no spacer. If there is a axle spacer, what is it called or part number if possible. Thinks for previous help on the tie bar, I believe I have found one.
