Mechanical to hydraulic brake conversion backing plate anchor point
  • Buster
    • 384
    Converting 1951 LE frame from mechanical to hydraulic brakes. Using 1958-62 backing plate and drum. I do not understand how you anchor the backing plate stud to the frame. is there a part in parts book I cannot find that connects backing plate anchor stud to a anchor point on frame. I found mention of a 87660-58 on web, but cannot any photos or anyone that has one for sale. Not sure if this part is relevant for what I need. Any photo of the anchoring method would be appreciated. Here are photos of my frame at axle and backing plate I am using.
    • 4783
    The part is called a tie-bar and is illustrated in the '61 parts book. That is the right part number.
    • ryan
      • Mar 2017
      • 610
      Buster,
      Do you have the anchor pin and parts for your backing plate?
      • Buster
        • 384
        I have wheel cylinder, small block at bottom, and anchor stud.
        • ryan
          • Mar 2017
          • 610
          Buster,
          I sent you a pm. I do not have the tie-bar, but I made a call to a guy that says he is pretty sure he has what you need to do the conversion, the tie-bar with a ball on the end, spacer and hardware.I
          From what I gather, the ball end fits inside where the manual lever comes thru and the other end has a hole in it to secure the anchor stud.
          • Buster
            • 384
            Ryan
            Apparently the PM has not come through to my box. I just talked to the guy I got backing plate, drum etc from and he says he thanks he has the tie bar. He will let me know in next few days and give it to me if he finds it. If he does not have it, I would like to see what your man has. Thanks.
            • ryan
              • Mar 2017
              • 610
              It made it through that time. Just my phone number.
              • Buster
                • 384
                I found the tie bar. Here is photo. The side plate bushing which replaces the regular axle sleeve is 87669-58. I believe it to be unobtainable, so I am going to machine one on lathe.
