Any opinions on what tire I should use on a 47 Indian with an Indian sidecar.
Sidecar tires
Tags: None
Since Indian had interchangeable wheels, I would use the same brand tire on the sidecar, that you have on the motorcycle. Not only would it look aesthetically good, but if you ever needed to put the sidecar wheel on the bike, it will match up. Also, the rear tire on the motorcycle will have a short life due to the nature of pulling a sidecar. The sidecar tire will last much longer than the tires on the motorcycle.Last edited by exeric; 07-23-2018, 02:29 PM.Eric Smith
