1940's INDIAN Sidecar Gearing Info Needed
  • motor-officer
    • Feb 2011
    • 199
    I am in the process of installing an original Indian sidecar on a 1947 Chief. The Chief has a stock 74 cubic inch motor with a 25 tooth front sprocket. I am hoping to hear from some current Indian sidecar owner/operators as to what type of gearing you run. Thanks for any help.
  • hairynob24
    • Feb 2011
    • 347
    G,day motor-officer i have had a 23 and 24 on my outfit for years running Bonnie cams ,i feel 25 is to tall,Hob
    • jcrawford
      • Oct 2002
      • 134
      When I pulled mine with my '48 stock 74 c.i. motor I used a 23 drive sprocket with and without a 150 lb.+/- passenger.
      • fillibuster
        red dog
        • Aug 2009
        • 934
        (haven't been here for a bit), .. The year I got my sidecar I was fortunate enough to acquire a handful of sprockets: 28-tooth, 27-t, 23-t, 22-t, and a 19-t, all good shape. The 19 was meant for the Rocky Mountain Road run of 1993 (?), and with my stock 47
        -74 inch I needed it. ... funny, when I tour the Black Hills I get around on a 23 just fine, but I always worked the heck out of the engine. Flat lands the 23 is okay, unless you get a head wind. ..... not sure whether you can still get the 22's and less, ... scout parts?
        happy motoring!
        • RonH
          • Jan 2016
          • 213
          I am running a 23 tooth on my 48 Runs great and I am in Florida.
          • Dana
            • Dec 2007
            • 31
            My Grandpa's '48 had a 17 tooth front on it. That was really too low unless you lived in the mountains. I don't. I've worked my way up to a 23 tooth front. Acceleration is fine, and I'd say the rig tops out at about 45-50 without really abusing the engine. Or at least my speedometer reads 50, but is likely a lot less. I think a 23 front is about right for around town.
            - Dana
            • D.A.Bagin
              • Jan 2008
              • 595
              Never counted my gear but I also find running between 45-50 is the spot. Any decent hill I'm downshifting.
