44/45 Indian Chief sidecar connections
  • 45OZ
    • Dec 2002
    • 270
    Hi Just pulled the 44 chief Sidecar parts out after sitting for a long time & since I have never hooked one up I am trying to figure out the connections & what I may need So...... Does anyone her have pictures of how the unit connects to the bike so I can try & figure what is here & what I may need also any Indian manuals or links that show anyparts that connect & how the should be properly attached? Thanks in advance for any assistance
    JoeCIMG6722.jpg Oz
  • 45OZ
    • Dec 2002
    • 270
    Also are there any #'s on the frame with these?
    • fillibuster
      red dog
      • Aug 2009
      • 934
      2 things from your picture:
      I can't see the yoke for the top of your "Johnson Bar", which 5/8" fine thread slips through the frame just in front of the seat post.
      Can't see the axle for the wheel.
      Odd, the fender is similar to the one I got w/ my sidecar when I acquired. I wear a full-skirt, had to fabricate it.
      Flop that frame over next to the bike (or a bare frame). Hang the front mounting bracket (check alignment on down-tubes to assure that it's Chief or Four). Attach lower yoke to bike's frame where the crash bar would normally bolt up, using the small yoke (size of your fist) with hinge part up. Last, place Johnson Bar in its clamps, and tilt it back to approximate position it would be in.
      Sorry, no pix here. My greasy side's down, paint up. .. Anybody else?
      • 45OZ
        • Dec 2002
        • 270
        Thanks fillibuster
        I will look for the Johnson bar Yoke, axle is there, Open fender is for the 44/45, No Front crash bars with side car? Will give it a go,
        I also want to let ya'all know that I am not in front of Computer everyday so if I don't respond right away I am not being rude just not computer Chained LOL....
        Oz
        • mike46chief
          • Jan 2011
          • 6
          Hi Oz,
          Did you get what you need as far as pix? If not let me know and I'll snap some shots of mine and post. I have a '40 SC on a '47 Chief so the mounts might be a different than yours but the general idea should be the same. Mike
          • hairynob24
            • Feb 2011
            • 344
            G,day Oz , there should be a number on the bar that run parrallel with the bike in front of the rear axle casting , paint may make it hard to see
            • L Burke
              • Jan 2013
              • 131
              Check with Michael Breeding, check his site and email him, he has excellent reprints of the Chief setup and parts numbers. Also check classicsidecar.com excellent photos and descriptions also try Willards Sidecars site, good information.
              Lb
              • RonH
                • Jan 2016
                • 213
                Originally posted by mike46chief View Post
                Hi Oz,
                Hi Mike, any pics of the mounting and the springs would be a great help, I just picked up a repop late 40's sidecar.
                • slink
                  • Jan 2017
                  • 2
                  Quote "Last, place Johnson Bar in its clamps, and tilt it back to approximate position it would be in."
                  What position should the Johnson bar be in when properly set up? Also, what are you adjusting as you rotate the Johnson bar into different positions?
                  • slink
                    • Jan 2017
                    • 2
                    Still looking for help with what position the Johnson Bar should be in when properly set up and what you are adjusting when you rotate it. A photo of someone's setup would be especially helpful.
                    • L Burke
                      • Jan 2013
                      • 131
                      Check with Michael Breeding, he has excellent reprints of the Indian Sidecar Material. Did you check Classic Sidecar....,.this very subject is a topic for discussion on Virtual Indian
                      Lb
