LE support steel
    • Feb 2003
    • 5353
    Originally posted by GTD View Post
    Cory
    Just to clarify things, the "drop" as measured between the yellow lines in the attach pic is: one and a half inches
    And the stud or pin is centered at half that distance or three-quarters of an inch ?
    [ATTACH=CONFIG]13279[/ATTACH]
    That is correct. I should however mention that not all of the bends appear to be perfect 90 degree angles. So that 3/4" could be somewhat interpretive depending on how close you get your bends.
    Cory Othen
    Membership#10953
    • GTD
      • Mar 2013
      • 20
      " .. not all of the bends appear to be perfect 90 degree angles. So that 3/4" could be somewhat interpretive "
      That's OK, the springs on my 67 year old Motor Car hack are also - somewhat interpretive !
      Should be a perfect match.
        • Feb 2003
        • 5353
        Well, it certainly sounds like you are well on your way. Keep us posted on how it all works out.
        Cory Othen
        Membership#10953
        • GTD
          • Mar 2013
          • 20
          That I will do !
