Sidecar setup
  • RR2
    • Nov 2011
    • 23
    Sidecar setup
    How do I make a toe in adjustment? I have the bike leaning out and measured the distance with parallel lines coming off the wheels of bike and sidecar. The front is wider than the rear by 5/8. Thanks
    • 4789
    What kind of bike? What kind of sidecar? Pictures?
    • RR2
      • Nov 2011
      • 23
      47 knuckle, 45 LE sidecar.was not sure if I could adjust the ball and locknuts or rear mount needed adjusting. I appreciate any direction.
        • 4789
        As I said, pictures. A normal LE with factory mounts on a '36-'57 model frame has the toe in factory set and only very minor adjustment is possible. Are your mounts correct? Are they installed properly? Is your frame bent? Sidecar axle bent? etc, etc. With no pictures everything is guesswork and a potential waste of time.
        • RR2
          • Nov 2011
          • 23
          I will send pics this weekend of sidecar mounted & apart at connection points.I had frame & front end checked at pro frame shop before build & have 4500 miles on so far with no problems without sidecar.Sidecar mounts are used OEM. later
          • fillibuster
            red dog
            • Aug 2009
            • 934
            I think that you are toe'd OUT. Mine (47 indian) is narrower front than rear, I think by 3/8" (?). The outward lean is maybe 2 degrees. Been good that way, did a lot of miles, hard running, changed a lot of rear tires.
            • RR2
              • Nov 2011
              • 23
              Thanks, That's what I suspect. I'm trying to attach pics for the first time, could be awhile.
