does anyone know of anyone reproducing the end pieces for gouldings? I picked up what I am told is a 40's goulding sidecar, I am going to mate it to my 57 panhead it had the sun burst/ pedal trim on the nose.
Goulding sidecar
Tags: None
Thanks Cory and Rob, Been trying to get some leads on the Goulding web site last Sunday but no replys from them as of yetChuck
AMCA Member#1848
Loyd, I left a message with him should you talk to him let him know I am still looking for the front lower mount. It goes to this portion of the frameOriginally posted by diesel55 View PostHello chuck give me a call i lost your number.i know a guy with some side car mounts. loydAttached FilesLast edited by Chuck#1848; 07-05-2013, 08:06 AM.Chuck
AMCA Member#1848
Hi Larry,Originally posted by L Burke View PostHi Chuck,
Needing the same trim, I am working with an excellent hand fabricator but needing a pattern or tracing with measurements. He has NC machines, plus skilled with an English wheel.
Larry
I have been talking to some people as well, but the problem that comes up is how to reproduce the raised edges on the trim pieces I think that they would have been stamped out to produce that detail on the edges.
You can magnify the photos to get a better look at the edgesLast edited by Chuck#1848; 08-04-2013, 01:03 PM.Chuck
AMCA Member#1848
Chuck, That part was stamped. I could reproduce the bead on my Whitney power roll but first you got to fabricate the roll. Second, you will never get it to look like the original stamped version. Soon as you hit that corner, it's going to wave even if I did it on a hand roller you'll never get it perfect. Chuck, I will be at Brookfield as long as it doesn't rain. Bring that thing with you and let me have a look at it. Bob L
Larry,Originally posted by L Burke View PostThis edge did not seem to present a problem to Bob, requires a roll process that seemed not to present a problem to him...I will forward your detail pictures and we will see where this goes.
LB
Did you get a chance to forward the pictures to Bob?Chuck
AMCA Member#1848
Hi Chuck,
Just back from Bonneville, no cigars here, but Bob thought he could fab from what he discribed as Dead Brass, then roll the edges. he would need the original to make a final decision, also the diameter of the sphere to insure proper fit to the tub.
LB
