manual brakes sidecar
  • shov-pan
    • Oct 2009
    • 5
    i want to convert a 1956 sidecar to hydraulic brakes any help with part numbers will be a great help. i think the backing plate is for a 58-62 panhead and can not find wheel cylinder 87750-58 is there any other cylinder that will work. thank you i am installing the sidecar on a 1965 panhead police bike
  • Sargehere
    Member since 1972
    • Jul 2006
    • 971
    It did use the parts from a 1958-era Hydra-glide front brake. Keep in mind that when the factory did the change, they had to take the third, the horizontal front brace out of the sidecar fender to have room for the hydraulic brake and backing plate parts behind it. Three braces = 1936-57, two braces = 1958 & later.
    Gerry Lyons #607
    http://www.37ul.com/
    • shov-pan
      • Oct 2009
      • 5
      i do not need any help anymore i bought a 1966 sidecar on this forum.thank you walt
        • 2018
        Walt That is probably a better solution. You might have had to cut the sidecar frame to get everything to clear. I have never done this converaion but have owned a few sidecars that were and they all have the brake shaft tube cut back.
        Jerry
        • jeffrro1
          • Dec 2008
          • 47
          If you would like to sell your 56 sidecar I am looking for one.
          Jeff
