HD cylinders
  • philippe
    • Oct 2018
    • 15
    HD cylinders
    hello
    can somebody tell me the difference between 1915 and later 1915 regarding cylinders
    i try to make comparaison using pictures but doesn't see any evidence!
  • knucklehead 61
    • Sep 2016
    • 350
    compare the fins around the exhaust valve cover.
    15 are curved.
    16 & up are flat.
    • philippe
      • Oct 2018
      • 15
      thanks for your reply
      I don't understand clearly what you explain, when you sau exhaust valve cover , where is it ?
      • philippe
        • Oct 2018
        • 15
        15 are curved.
        16 & up are flat.
        you are talking about the vertical or the horizontal fins?
        • knucklehead 61
          • Sep 2016
          • 350
          the horizontal fins near the bottom of the cylinder. they almost touch the valve spring cover on a 15, but are not close on 16 & up.
