1911 Harley Davidson Single Cylinder Wiring
  • RicD13
    • Jul 2013
    • 10
    Does any one have a wiring diagram for an 11 single battery model? What is the best battery to use? Have a 12volt coil.
    Thank you,
    Ric
    • 6029
    This is a typical wiring diagram for an early battery ignition system. In the early days, motorcycles used those big round dry cell batteries that were common up into the 1970s. 12 volt will work fine, but if you're trying to replicate the correct look, you'll most likely have to fabricate something on your own. Hope this helps.
      • 6029
      Did you ever figure it out, Ric? Is your bike all genuine 1911 Harley-Davidson?
      • talbot-2
        Member 1967-1978, 2007-
        • May 2009
        • 270
        I have a 1912 Harley-Davidson single, battery ignition, and have used No. 6 reproduction dry cells for several years. They have 2 "D" cells inside wired in parallel that are replaceable. The dry cells look like original old dry cells and have proved to be very satisfactory. They can be purchased from "Ken's Clock Clinic" for $36.95 each. Check out Ken's website and/or contact him at ken@kensclockclinic.com. I use three of the dry cells in my 1912.
          • 6029
          Talbot-2, always great to see a post from you. Just curious if you looked at the page I posted with the coil trembler. Are you familiar with the 'trembler' feature. I have to wonder if the trembler was one of those do-hickies that picky riders could not stop fiddling with.
          • talbot-2
            • May 2009
            • 270
            I'm not familiar with a "coil trembler". Where can I find your post on it? By the way, I use the repo dry cells in my other two battery ignition cycles as well without any issues.
              • 6029
              It's in post #2, in the attachment. The trembler is described in the last part of the article. I asked because I had never heard of one, and wondered if it was one of those pointless devices that progress threw out the window.
              • talbot-2
                • May 2009
                • 270
                Got it. I have never heard of the "trembler coil". I looked through all of my early battery ignition data to no avail. It is an interesting concept. Just don't see it's value. Like you said, it is probably one those pointless devices that progress threw out the window.
                • Tommo
                  • Sep 2001
                  • 1320
                  Model T Fords among others used trembler coils for many years
                  Peter Thomson, a.k.a. Tommo
                  A.M.C.A. # 2777
                    • 6029
                    Thanks, Peter. You always come up with great answers to the strangest questions
