corbin rear hub exploded view needed
  • aka HAWG
    • Jan 2007
    • 487
    any one have an exploded view of a corbin rear hub, i have parts book view but does not show order
    is for a 1914 excelsior
    aka HAWG
    1914 EXCELSIOR BELT DRIVE SINGLE
    1914 excelsior belt drive single carcuss
    1940 indian chief military
    1965 sportster xlch
    1969 sportster xlch bobber
    1971 bsa A65 chopper
    1969 harley ss350 sprint
    1960 harley topper
    1963 harley topper
    H model whizzer on cheiftain bicycle
    H model whizzer on schwinn bicycle
    1949 harley model 125 bobber project
    1959 harley model 165
    1960 harley super 10
    1974 indian 70cc dirt bike
    EXCELSIOR - ALWAYS MAKES GOOD
  • gww
    • Dec 2011
    • 143
    evening Dave, if Gene Harper is available. he d prob. be able to give you the order. got to say he s a very helpful guy and like some others has spent allot of time researching. . are you Cannonball n this in 2015?
    gww57.com
    • aka HAWG
      • Jan 2007
      • 487
      hello gary
      i think i've worked it out by looking at parts book and slowly taking rusted hub apart but will try to contact gene
      as for CB 2015 unless i win the lottery being a long haul member probably is not in the cards( time off from work and the costs ), depending on route could bring the "X" to a stop point as ill go to see it anyway as i have for the first two and plans in work to attend a stop point in 2014
      hope your frame arrives soon and hope to see you in tenn on CB 2014
      aka HAWG
      1965 sportster xlch
      1960 harley topper
      1963 harley topper
      • gharper
        • Nov 2009
        • 528
        Dave,
        I don't have an exploded view of the corbin hub, just what is in the X parts book. It's a complicated mechanism but keep playing with it,it will finally fall together.
        Gene
        • Paulvenne
          • Mar 2007
          • 24
          Hawg, I have been having a problem in the transfer sleeve backing up against the uncaged balls of the starter chain on the right side. Seems there should be a washer or something so I asked around at Dixon and a chap with a museum up in Washington told me that the pin that goes in the channel should also be the stop. I'm looking into that. I put a query into Walker Machine who made my transfer sleeve, but no reply yet. Next I take apart the hub again and look at the thing. Hope this helps. The balls in each bearing should be caged, but most of mine weren't. Thank you, Paul V
