Excelsior crank pin differences, flywheel assembled width, cam covers, valve spring
  • Scooter6
    • May 2025
    • 31
    Good evening,
    I have been working on an 1920 Excelsior engine from parts for years some of you have helped with when I was a member 20 years ago. I have more time on my hands now and would love to complete it.
    I have questions on some parts.
    I need a cam cover and I see some with one hole for cam stud bolts and some with three holes. Besides that, do they interchange? Because I would take what I could get and does not need to be perfect.
    I need a crank pin for the connecting rods and I am wondering if it is supposed to have oil holes because the flywheel has a hole? I would take one not perfect since this would not be run much. I have half a frame and tank and wheels and plan to build a fake racer or just display the engine.
    How wide should an assembled crank be measured across the flywheels at the crank pin if I need to make one.
    Does the connecting rod have shims between the flywheel? I do not see a part number but saw pictures of parts the look like that.
    How thick is the bushing flange on the right side? I need to make a bushing it is missing.
    What is the length and wire diameter of the exhaust springs? I have one that came with the parts and seems long and would compress a lot to install and seems like a lot of load. It is almost 3" long.
    Please let me know what you know or if you have a crank pin or cam cover.
    Thank you,
    Scooter
  • Scooter6
    • May 2025
    • 31
    Good evening,
    I am adding photos showing an adapter someone added to the cylinder to adapt big valve intake. the inlet was machined and looked like they cut off the original so I though I was in for a lot of work. I have been reluctant for years to attempt the removal but when heating it to melt the braze I notice a difference in color between the adapter and a smaller diameter at the inlet so I stopped and measured to believe the original thread may be there and turned out to be correct. I had to ad a reducer to the inlet because it was machined bigger.
    Scooter
    • gharper
      • Nov 2009
      • 528
      I've had some cylinders like that. Someone did a ice job of making a screw on increaser, then brazed it on. I was able to heat it up and unscrew it, revealing nice original threads. Also had to install a bit of a reducer in the port.
