Neracar - Brown and Barlow Carb
  • danf19
    • Apr 2013
    • 246
    I am wondering if anyone knows the threads and size of the fuel inlet connector for the Brown and Barlow carb on my Neracar project. I have tried a thread gage but nothing I have seems to fit.
    As you can see from the pictures there is a fine and coarse thread. I am trying to make up a fuel line.
    Conversely, Does anyone know what the size the Neracar fuel lines ends ( carb and tank valve) were ??
    As always, thanks
    Dan
  • MMasa
    • 1192
    Have you checked to see if it's a metric thread? Maybe it's a British standard Witwoth?
    Mark
    Mark Masa
    www.linkcycles.com
    • danf19
      • Apr 2013
      • 246
      Mark:
      thanks for the reply and although I don't have a whitworth thread gage, I believe you are correct.
      Although I still have a lot to learn with my machining skills , I think I will try to rethread with something a bit more common.
      I am using a Harley Davidson JD/Vl petcock off the bottom of the Neracar tank. Would you or anyone know offhand the thread size and type of the Harley petcock ??
      As always,
      thanks
      Dan
      • Tommo
        • Sep 2001
        • 1320
        If you ran a vernier over the outside and gave us an idea of the sizes we might be able to assist you a lot easier.
        My guess is that the fine thread is BRITISH CYLINDER Thread and going by my B&B carbs would be 9/16 x 26 TPI thread.
        The coarse thread looks like 1/4 BRITISH STANDARD PIPE thread and if it is it will be 19 TPI.
        BSP differs from the American NPT thread by 1 TPI.
        1/4 BSP is 19 TPI whereas 1/4 NPT is 18 TPI
        They both should measure close on 1/2 inch over the tops of the thread.
        HD fuel tap thread is 15/32 x 24 TPI.
        Those B&B elbows are hard to find so please don't destroy such a lovely original part.
        I do have the HD tap nut and bull nose that goes on the end of the fuel line.
        We have made a run of these in brass and they sell for $25.oo the pair. (1 nut and 1 nipple)
        Peter Thomson, a.k.a. Tommo
        A.M.C.A. # 2777
        • bobbyt
          • Mar 2008
          • 98
          Be aware that most British Standard threads are 55 degrees rather than 60. BSC (British Standard Cycle) were 60 degress though, I think. Most BSC were 26 tpi.
          Bob Turek
          AMCA #769
          • danf19
            • Apr 2013
            • 246
            Guys:
            thanks for all the help. Peter, PM sent,
            thanks to all,
            Dan
