Wanted For 1925 Excelsior Super X
    • Aug 2001
    • 1343
    Wanted: Rear Fender, Front Wheel, Front and Rear Axles, and Chain Guard for my 1925 Super X. Thanks for any help!
    Louie
    YouTube >>> LouieMCman
    • 5979
    Sounds like you're making progress on your Super-X, Louie. Tough bike to do, but worth the effort.
      • Aug 2001
      • 1343
      Ya, just look at all the responses I'm getting!
      Louie
      • len dowe
        • Oct 2002
        • 503
        Like they grow on trees.
        AMCA #765
          • Aug 2001
          • 1343
          Latest pic....
          Louie
          • ammorest
            • Sep 2008
            • 292
            Louie, brake drum is on the way to you.
            Dave
              • Aug 2001
              • 1343
              Thanks Dave I sent you a private message.
              Louie
              • gharper
                • Nov 2009
                • 525
                Louie,
                Yesterday i sent you a PM with a lead for a front fender. Contact me if that didn't go through.
                Also tried to post this message but for some reason it didn't work. So...
                Here is an option for fenders, Vintage Steel in Australia: http://www.vintagesteel.com.au/ They roll fenders for a varitey of motorcycles. I had them make 2 blanks for 1920 Excelsior (Same as Deluxe) and an Indian sidecar fender. Very nice work indeed, but not cheap. They list a front fender for Super X, complete with skirt: http://www.vintagesteel.com.au/mudgu...super-x-fender
                If you can get a measurement on the rear fender I would suspect that it is the same cross section and radius as the front but much longer. If so, they can roll a blank for you and you can fit it to the bike. The ideal thing would be to have an original to borrow as a pattern for the braces and holes as well as any cutouts that were made. It's an arduous process, but in the end you would have two new fenders.
                Good Luck!
                Gene
                  • Aug 2001
                  • 1343
                  Gene, I replied to your PM last night. I got a nice front but no rear fender, thanks for the fender link, I think they need to make a batch of rears! I also need a mag, I got a nice Splitdorf 42 degree for sale or trade.
                  Louie
                  • gharper
                    • Nov 2009
                    • 525
                    Louie,
                    Contact them at Vintage steel. They may have rears in the works, but if not, they will make them for you if you can give details. I took an original Princess sidecar fender, laid it out on paper and traced it for the radius, other dimensions and tracings as needed. Mailed that to them and they made a perfect replacement from there. So if you can borrow an original, or get someone to trace it for you, you're in business.
                    All you need to make that mag correct for your Super X is a different cam, 45 degree, different id tags (S-2 1613) for the magnet cover and a slight modification to the advance lever hole (increase id to .257"). Other than that, they are exactly the same! Here is a link to Splitdorf mag id sheet from my web site: http://www.splitdorfreg.com/Splitdor...tdorf-Apps.htm
                    Contact Kent Thompson, he may be able to help with a cam etc.
                    Gene.
                    • veterannorton
                      • Feb 2010
                      • 18
                      We can make the rear fender for your Super X and we currently have the correct blank fenders in stock . I have an original machine to copy the rear fender from
                      Antique historic vintage veteran classic custom heritage collectors motorcycle bike motorbike caferacer streetbike fenders mudguards reproduction new parts for sale
                      • veterannorton
                        • Feb 2010
                        • 18
                        Vintage steel have the rear fender blanks in stock and can make the rears on demand .
                        Also fronts with or with out valances
                        Andrew
                          • Aug 2001
                          • 1343
                          Do these look like your fenders, i bought them in Germany.
                          Louie
                          • bbinns
                            • May 2016
                            • 36
                            Whats the battery box youre using there Louie? Ive been looking for an original on for a 1925/early26 but cant find one.
                            Your bikes really coming together, looks great!
                              • Aug 2001
                              • 1343
                              Funny you ask...it's a $5 ammo can that was close in height and width and I shortened it a few inches, has hinged top, seems to work OK for now....
                              Louie
