Electric starter identification | Indian Chief 1946
  • Igor
    • Apr 2026
    • 37
    Does anyone have any idea what brand this electric starter is?
    It is 12V and features a combined starter/generator unit. You operate by it using the horn button.
    Unfortunately, the starter/generator has burned out.
    I'm torn between keeping this setup or converting it back to original (while maintaining a 12V system).
    If anyone has any advice or experience with this starter kit, I'd love to hear it.
    Thanks in advance.
    This gallery has 5 photos.
    Igor – The Netherlands
    1948 Indian Chief
    Learning while wrenching​
  • tomfiii
    • Jun 2007
    • 314
    Maybe an starter-generator.
    • PaulCDF
      • Aug 2019
      • 1422
      Igor; any pictures from the Right side? Can see a kicker arm in the photos is it a working kicker or a "faux"? Does not look like Kiwi or Wombat. Maybe Fusco or a Timmerman though I have never seen either.
      • Igor
        • Apr 2026
        • 37
        Hi Paul, thanks for the reply. Yes, the kicker is fully functional, not a faux one. Here are some photos of the right side! Let me know if this helps identify the setup.
        The Chief was imported from New York to The Netherlands in 2012. I don't know if the starter kit was already on the bike then or installed later here in Europe.
        Since the kicker fully works, any idea which kit this could be?
        This gallery has 2 photos.
        1948 Indian Chief
        • Igor
          • Apr 2026
          • 37
          Hi Tom, thanks for your reply, yes indeed, it's a starter-generator.
          1948 Indian Chief
            • 1675
            Are the fasteners metric?
            • Igor
              • Apr 2026
              • 37
              Thanks, good question Harry!
              I checked the bolts and they are imperial/SAE, not metric, except for the threaded holes marked in the photo, which are metric.
              These are intended for metric bolts so you can easily press/pull the plate with the bushing out of the primary cover.
              This gallery has 3 photos.
              1948 Indian Chief
              • PaulCDF
                • Aug 2019
                • 1422
                Igor
                As bike came from Europe may be a Timmerman as I think they were made in Germany.
                Any chance you can contact the previous owner for info?
                On fb there are a couple Indian Groups: could post pictures there and see if anyone could
                give positive ID if you are not on fb with your permission I could post and ask for you.
                • Inchief
                  • Jan 2014
                  • 35
                  That was a starter - generator system that a fellow from I think Denmark was developing. The generator was also the starter motor. Ed Glasgow was thinking about selling them but I guess the design had some problems and the project got scrapped. Seemed like a good idea that just didn't pan out. You might try Ed and ask him if he has any leads on the fellow who was making them.
                  • PaulCDF
                    • Aug 2019
                    • 1422
                    Ed is a Great Guy helped me in past:
                    Eds Indian Bolts ed53ind@aol.com
                    315-696-8076
                    • Igor
                      • Apr 2026
                      • 37
                      Thank you so much! This is very helpful, I will reach out to him.
                      1948 Indian Chief
                      • Igor
                        • Apr 2026
                        • 37
                        315-696-8076
                        Thanks again Paul! I'll send Ed an email.
                        1948 Indian Chief
                        • PRG
                          • Nov 2006
                          • 612
                          Howdy chaps,
                          I could see where that setup would have issues. In order to develop enough start torque from that small generator sourcing power from likely a lead acid battery limited in size to the stock mounting location it is dramatically under geared in the start cycle and over geared on the charging side. Besides overwhelming bearings and brushes, don’t think a mechanical regulator could duty cycle rapidly or accurately enough to control charge rate.
                          Cheerio,
                          Peter
                          #6510
                          • Igor
                            • Apr 2026
                            • 37
                            Originally posted by PRG View Post
                            Howdy chaps,
                            That definitely sounds like what happened here. In the meantime, I spoke with a mechanic who is familiar with these Dutch electric starter kits. He mentioned seeing issues with them on other bikes as well, specifically that the gear inside the primary cover is too weak to handle the torque. When it fails, it leaves the entire primary drive packed with metal shavings.
                            At this point, it's a total no-brainer for me: this kit is coming off. I'll keep the 12V conversion, but I'm taking the rest of the setup back to original.
                            Thanks for the info and help!
                            1948 Indian Chief
                            • PaulCDF
                              • Aug 2019
                              • 1422
                              Thanks for the follow-up
