1934 vl
  • burch
    • Apr 2012
    • 20
    1934 vl
    I am trying to straighten a frame for a 1934 VL. Can anyone help with the dimensions and specs. Thank you.
    Sorry I missed your call yesterday. My frame guys like to see the frame with the forks and wheels on as a rolling chassis. Inside front fork rockers is about 7.5" and inside rear frame is about 8.5" where the wheel goes through. A rod through the headstock should be at right angles to the axles. Engine mounts should be flat and fit the crankcases. Footboard support rods should be square with the frame and so on. It's a strong frame but a head-on crash will bend the front downtube and cock the headstock. Careful viewing from the rear will usually show what needs doing.
