original spark plugs
  • linus
    At Davenport i had points deducted for not having period style plugs. can i switch the plugs prior to judging? i intened to ride to the meet, but the plugs i picked up are shot. any advice?
    thanks,
    Linus
    Switch for show. Switch back to modern for running.
    • kval
      Linus
      when you are at the meet make sure a judge, deputy judge, national deputy judge, assistant chief judge or the chief judge see's the bike running that weekend, then switch to the original style plugs for judging
      Kevin
      • linus
        guys,
        thanks for the advice. i'll make sure i get a hold of someone when i get there.
        linus
          Linus, (is that your real name?) a couple years ago I fouled a new plug out in Oley in my '20 HD and was surprised to discover that the bike actually ran better with a good set of original plugs I use when judging. Give it a try.
          Louie
            Why do think that happened Louie? Are they hotter? Just curious- not putting you on the spot or anything.
            • linus
              louie,
              beleive or not, that is my given name i'll give them a try and see how they work. depending on how hard they are to come by i may still stick with the switch prior to judging.
              linus
                I don't think the plugs are hotter, but I have been running them the last year or two with good luck. Maybe someone else can explain it?
                Louie
