Birch white match
  • Rick
    • Jan 2011
    • 3
    Birch white match
    Does anyone know a close match paint code to match birch white that I can pick off the shelf from an auto parts store. I had one that was a Honda car color that matched but I seemed to have misplaced it.
    Rick
  • Rollo
    • Nov 2008
    • 599
    Rick,
    The way I was told by reliable sources is that Birch White was a standard GM color for many years. I would think any body or paint shop should be able to give you the code and bop on down to the AP store to get it.
    Tom (Rollo) Hardy
    AMCA # 12766
    • t-jacobs
      • Jan 2008
      • 130
      When I had my 64FLH painted the painter said he had no problem with getting birch white by using the Harley color code #. The Hi Fi red was another story.
      • Sportster Jerry
        • Jul 2007
        • 165
        I was told 1968-69 Ford Wimbledon White is a very close match.
        • 58Tin
          • Mar 2009
          • 9
          I am looking for the same thing. What I found so far was 2010 Hummers had a Birch White color. The Dupont paint code is B8550. Just not sure how close it matches the original Harley color.
          • Rod K
            • May 2006
            • 179
            I don't know the first thing about paint. I had a bike painted about 20 years ago. Had the paint mixed by an old shop in Milw who said they had the factory codes. I still have the can, It reads: PPG Duracryl Acrylic Laquer Ditzler Finishes #DDL 90303 Birch White.
            Hope that helps and you can make sense out of that.....Rod
            • hennigan62
              • Sep 2010
              • 140
              Just find a sherwin Williams auto paint shop.they have code for birch white. Did a spray out and it is dead on to my 62' original paint.
              • longhorn
                • Feb 2008
                • 33
                Harly Davidson still uses birch white and sells birch white in their dealerships.
                • GPettigrew
                  • Dec 2011
                  • 1
                  Dupont has a Birch White specific to HD.. Their code is AV and Dupont #809233K Any store that carries Dupont should be able to mix it for you
                  Greg
                  • moon wolf
                    • Jul 2009
                    • 83
                    I believe the new birch white is several shades different from the old birch white.
                      • 5950
                      What Harley color code?
