Removing rattle can paint
    • 5955
    I have found some wonderful stuff for removing rattle can paint. It removes rattle can paint and if removed quickly doesn't usually disturb the factory paint underneath.
    It is "OFF" Vandalism Graffiti Remover. Distributed by American Industrial Supply, 1-800-366-0961. I buy it at a professional janitorial supply store. If you can't find it call their number and find out who they sell it to in your area.
  • gator
    I ant like that anymore!
    • Feb 2012
    • 3
    Thanks for the tip. I just got a 21" wheel and hub someone went crazy on with flat black spray paint. It's got stainless spokes so OFF should do the trick if I can find some....gator
    " I ant like that anymore!"
    gator's sugarshack
    http://gatortransport.vpweb.com
    • gharper
      • Nov 2009
      • 528
      I've used "GOOF OFF" graffitti remover. Comes in a spray can and is available at most hardware and home inprovement stores. Same story, removes rattle can paint and leaves the original finish, IF removed fast enough. I was able to remove 30 uear old red primer from the wheels of my 19X and revealed pretty good original paint and stripes.
      Gene Harper
