'55 Panhead exhaust paint
  • felthamw
    can't re-Member
    • Aug 2008
    • 92
    Any suggestions (color, procedure, and type of paint) to match factory paint on head pipe(s), "y" pipe and "s" pipe?
    Thanks, and what a great forum this is!
    Wayne
    • 5950
    High temp exhaust paint, silver or aluminum color.
    • George Greer
      • Jul 2007
      • 151
      Chris...
      do you have photos of this size for a Type III WLA you could email me?
      George
      George Greer
      AMCA # 3370
      • felthamw
        can't re-Member
        • Aug 2008
        • 92
        Beware!
        Not just any silver or aluminium paint will suffice in the judges eyes. I used Hi-temp silver VHT (because it was the brighter of the two) and it still didn't pass judgement. The end result was too gray. I was told that it was supposed to match the H-D aluminum paint. The word 'Hirsch paint' came up. Any ideas on who has used it in the past and if it is available ..... where?
        Wayne E. Feltham #4329
        • Rod K
          • May 2006
          • 179
          exhaust paint
          The name Hirsch paint is unfamilar to me. I can tell you what I used, and that is the current
          Harley Davidson " Heat Resistant Silver Paint " part # 98660-78. Someone recomended it to me. Got it at the HD dealers. First time I'v been in a dealership in a looong time. It's nice and bright, I was happy with it....Rod
          • Rooster
            • Mar 2009
            • 543
            Are you talking about the paint, or the Dealership?
              • 8233
              "Restomotive"s POR 20 is the most heat resistant aluminum coating that I have found, and it suits me fine to represent "silicon aluminum" or whatever the original might have been in Factory pics that fools so many to think they were plated.
              A propane torch doesn't faze it!
              But just like POR15 it has just one fatal flaw:
              It doesn't prevent rust under normal conditions.
              • Rod K
                • May 2006
                • 179
                Rooster.....The dealership was nice and bright also...I kind of liked the old dingy ones in the
                60s with all the chopper take off stuff over in the corner...Rod
                • felthamw
                  can't re-Member
                  • Aug 2008
                  • 92
                  heyyyyy... easy, Rod. I bought that stuff and it is still on MY chopper!
                  Wayne
                  • Rooster
                    • Mar 2009
                    • 543
                    Those are the ones I remember. A little grease on the parts counter, where you could pull up a stool and light up a smoke. And not a T-shirt to be found...!
                    • felthamw
                      can't re-Member
                      • Aug 2008
                      • 92
                      Problems......
                      I just got done re-painting my exhaust (and fixing a myriad of other issues) and finally fired up the bike. It's been since Oley.
                      Immediately, my garage was filled with smoke that was emanating from my new paint job on the exhaust components. Not only that, but that BEAUTIFUL satin smooth finish is g-o-n-e! The "s", "y" and rear header pipes now all look as rough as the painted cast cylinders. And the front header did something completely different - it bubbled.
                      What the heck?
                      I had lightly bead blasted the components, not completely removing all of the VHT Silver paint I originally painted them with (and was judged to be too "grey").
                      I then cleaned the pipes with JP-1 aerosol (alchohol) and painted everything at one time with H-D Silver heat resistant paint exactly according to the directions on the can. No curing procedures were done (as none were listed on the can).
                      I just don't get it. Contamination or humidity can't isolate to individual components as it did.
                      Does anybody out there have any expert wisdom that can lead me further down this crooked path? Another "do over"! This exhaust has cost me 1/2 point every time. Little did I know it would be such a pain in the #$@. I guess it is true that the devil is in the details.
                      I guess now I should strip it all completely down to bare metal and simply repaint again with H-D Silver heat resistant - but can it handle the heat? Will it retain that smooth satin finish? Or will it roughen up?
                      Crying in my soup,
                      Wayne #4329
                      • Rod K
                        • May 2006
                        • 179
                        Wayne, I have used the HD silver high temp paint on my 48 Pan Head cylinders and got about 600 miles on them. So far so good. My exhaust is painted black. Good luck...Rod
                        • Iacovos
                          • May 2012
                          • 208
                          Hello everyone
                          In Palmer’s 3rd edition it says that the exhaust except y pipe and s pipe are painted silver.
                          i had the opportunity to see a 60 FLH in a museum with 6000 miles on
                          however i do see the s pipe painted as well
                          so i am a bit confused
                          Were all pipes (except muffler) painted and is this a typo in Palmer’s book?
                          Or has the bike i am looking at been tampered with?
                          ease see pics
                          Also can you tell if the muffler is oem?
                          Thanks a lot
                            • 4784
                            Originally posted by Iacovos View Post
                            Hello everyone
                            ease see pics
                            Thanks a lot
                            You are reading it wrong. it says BT S and Y are not painted silver, that is because they are chrome finish as per the finish list.
                            • Iacovos
                              • May 2012
                              • 208
                              Thanks again Rubone! This is what i have written above
                              “Except S and Y pipe”.
                              However on the pics i have posted above (again here) does the S Pipe not appear painted silver? Looks like it! This is a 60FLH with 5900 miles
                              Thanks a lot
