Painting rims and aluminum cases
  • DanM
    • May 2005
    • 465
    Hi- I'm restoring a 26 JD.
    The cases need to be painted. Any advice on a good primer and prep for the aluminum ? Any different than the sheet metal?
    On rims, is there any attempt on the spoke holes to prevent build up? I had a set of rims dome once that had terrible chipping around the spoke holes when the spokes were tightened. I'm wondering what technique should be applied here?
    Thank you.
    Dan Margolien
    Www.yankeechapter.org
    Pocketvalve@gmail.com
    • 5950
    You must use zinc oxide paint on the cases. Regular paint will wash right off aluminum.
    • PaintPro
      • Jul 2008
      • 8
      Paint for cases and rims
      When painting older motorcases it's important to get them very clean first and then mask off any areas where you don't want paint. Once that's done I use what's called an etching primer. It makes a very tight bond with things like aluminum or galvinized surfaces. With the world going green zinc and chromates are being phased out of paints. Once the primer has dried I use a catalyzed acrylic enamel or urethane on the parts. I have done about 25 set of motor cases with no peeling problems reported. Any local auto paint store can help you with the selection of the proper products to use.
      For clearing the holes on painted rims I used a straight sided reamer of the correct size held in a tap handle and just give it a twist or two in each spoke hole. This will remove the paint with enlarging the hole. measure your psoke nipple to get the correct size reamer. The second choice is a drill bit of the corret size again used with a tap handle so it can be carefully controlled. You can try masking the spoke holes with some kind of plug but more times than not you will cause a tear or chip in the paint when you go to remove it.
      • DanM
        • May 2005
        • 465
        thanks!
        Thanks Chris and PaintPro for your tips on the primer- and the idea of reaming the painted spoke holes!
        I have Centauri acrylic enamel from Antique Cycle Supply. I was planning on adding a hardener.
        Dan Margolien
        • stevekleincustom
          Steve Klein
          • Feb 2008
          • 196
          Aluminum and Paint
          The replies you got are correct. I have always cleaned the aluminum with an aluminum acid etch product that painters use on aluminum truck trailers, horse trailers etc.... Rinse clean thoroughly...then I use a zinc oxide primer. Quality paint properly mixed is the last step.
          I am not an advocate of powdercoating on vintage machines although it is a wonderful product for rims. It is tough and chip resistant and will not cause problems with spoke nipples.
          Steve Klein
          Steve Klein
          Collector . Conservator . Enthusiast
          American Pre-teens - 1965
          AMCA Member 12176
          Cherokee Chapter President, Editor
          www.CherokeeAMCA.org
          Steve@SteveKlein.com
          Georgetown, TX USA
          • bobdo
            • Feb 2003
            • 280
            Dan M,
            I've been using the Acrylic Enamel from Antique Cycle also. The primer I've used in the past was a PPG product called DP-90. It had lead in it so its not available anymore. It was replaced by DP-90LF which I'm using now. Of course the old stuff was better, but this is working out well on sheetmetal. I can't say about your cases, no experience there. The DP-90LF is an acid etch black primer. Hope this helps. Bob
            Bob
