1965 FLH Birch White tank panels
  • 67sidecar
    • Jan 2011
    • 33
    Can anyone tell me how / where the birch white accent panels were masked off on the inside or frame side of the tanks? Specificilly, with regards to the lower tank mounts, did the birch white cover the inner surface or only the outer surface? Can’t believe the factory took too much time masking across the entire inner tank surface, but near the front of the tanks it’s somewhat visible and would be important to get it right. Thanks in advance for any info!
  • KNUCK
    • 826
    • KNUCK
      • 826
      I just sold my All original 65 so this is all I have for you to look at as far as tanks. I only had the tanks off once and don't recall any white on the inside or frame side. Except for an inch or so, was all black.
      • paddy
        • Apr 2014
        • 219
        This is a set of OP 65 tanks I have for sale
        This gallery has 5 photos.
        • 55tmm
          • Dec 2009
          • 158
          Original paint '65 tanks
          • 67sidecar
            • Jan 2011
            • 33
            Huge thanks to everyone for the information! One interesting thing I noticed on the reverse pattern paint scheme tanks was based on the overspray it appears the upper (main) color was applied last. The standard pattern paint scheme, photos from Paddy, it’s what I would have expected, the main color was shot first then the birch white panels were masked off and shot. Thanks again and happy new year to all!
            • 55tmm
              • Dec 2009
              • 158
              Here is another with white bottom.
