Paint Methods for Indian Motorcycle Parts 1949-1953
  • JTR249
    • Jul 2019
    • 768
    I would like to know if anyone can tell me if it is okay to apply additional coats of paint after letting paint cure for a week?
    I used rattle cans to paint a set of Indian vertical tool boxes and have two coats of flat black primer and two light coats of high gloss black paint on them. I did not have any JP 1 Fast Black as planned, so I used Rustoleum primer and paint as many people say--match the brand of primer and paint to prevent future flaking. I don't know if that's true.
    If I wait a week or more to add a couple more coats, will the paint still be just as effective.
    thanks.
    -JR
    36450
  • motor-officer
    • Feb 2011
    • 199
    I primarily use Rustoleum paint products. I believe they recommend to re-apply additional coats with-in 1 hour or after 48 hours. I have never had any problems with re-coating
    days or weeks later.
    • painterdale
      • Oct 2013
      • 423
      I would give it a good scuff with a Scotch Brite pad and you should be good to go.
      Dale
      • joe fxs fxr
        • Dec 2020
        • 700
        Dale
        This is what I was going to say
        AMCA #41287
        1971 Sprint SS350 project
        1972 FX Boattail Night Train
        1972 Sportster project
        1973 HD Golf Cart project
        1989 Springer Softail project
        2020 Heritage Classic 114
        • JTR249
          • Jul 2019
          • 768
          Thank you all for your suggestions. I will take your advice, wait, re-apply and then use the Scotch Brite pad. Is this pad what makes the metal appear smooth as glass?
          I was kind of frustrated when I tried to paint my own Scout fenders. The finish is not as good as my pre-restored gas tank or oil tank. I even used spray lacquer in the suggested two coats, though I did not follow up with any additional work. Now I will try this and see what happens.
          Thanks again.
          -JR
          • painterdale
            • Oct 2013
            • 423
            Hi, JR!
            The Scotch Brite pad is going to slightly rough up the surface to provide a mechanical bond for the paint to stick. To be clear, Scotch Brite, then apply paint. After the first coats of paint sit for a week, the surface "closes up" and you lose the potential for a chemical bond so you need to provide a "tooth" or mechanical bond for the paint to stick. It's also a good time to catch any imperfections in the first coats by light sanding with 500 or 600 grit paper. The following coats should go on nice and smooth. Hope this helps a little.
            Dale
            • painterdale
              • Oct 2013
              • 423
              Chuckthebeatertruck has lots of great paint tips in his thread, "Let's build a girl's bike: a !967 Sportster XLH".
              Dale
              • JTR249
                • Jul 2019
                • 768
                Thanks Dale. I'll check that out.
                -JR
                • JTR249
                  • Jul 2019
                  • 768
                  Here's a few preliminary results.
                  -JR
                  • PRG
                    • Nov 2006
                    • 614
                    Howdy Dale,
                    Wouldn’t you say with the lack of solids in aerosols and corresponding thin film thickness that one might be better off, if desired, wet sanding very carefully with 800-1500 between final top coats to avoid cut-through, especially on edges. In contrast to decades of shooting gravity feed high solids decided to paint all 60 plus pieces of my Black Shadow below with Lowe’s sourced aerosols, experimenting with heat and various applications along the way, man was that an education, both then and now long term....have gone back to conventional gun applications since.
                    I had chatted with the widow of the owner, killed at age 62 on his Ducati, for many weeks every Saturday at 10:30 am sharp. At the point where she decided to sell it I was to be there at ....10:30 sharp. So I Google mapped her address, parked around the curve beyond site of the house and pulled up exactly on time to find much of it hauled out of the basement and garage sitting in the driveway.
                    Cheerio,
                    Peter
                    #6510
                      • 6029
                      Last Monday I finished painting the standard black items on my '51FL. I don't have a problem with high quality aerosols and think they have become much better over the years. However, you can't beat name brand automotive paint, shot from a good gun. It is expensive, but if this is a lifelong hobby, and one expects to do more bikes in the future, the costs will come down, and the quality will stay high. I just bought a 1 quart can of black, wet look hardener, and the corresponding reducer at a cost of about $80.00. The paint is already quite hard, and will only get more durable as it cures. I painted the inner, and outer primary, oil tank, chain guard, brake drums, seat T, tool box, damper assy., and horn and barely dropped the level in the can of paint. Painting is 95% preparation, and then 5% anxiety when you're actually painting. After that, it's 100% self satisfaction.
                      • JTR249
                        • Jul 2019
                        • 768
                        PRG and exeric,
                        Thank you both for sharing your advice and experience. Paint work has always seemed very sensitive to me. You have to be careful or you will ruin the finish.
                        I had an employee of BD Cycles tell me I should use as many as eleven coats on the frames when restoring Indians. I only used 2 or 3 and then I saw why. With the slightest nudge into another metal part, there was scratching and a slight flaking, often right down through the primer.
                        I have a compressed air system, though have never used it. Maybe I will learn this summer.
                        Kind regards,
                        -JR
                        • painterdale
                          • Oct 2013
                          • 423
                          Originally posted by PRG View Post
                          Howdy Dale,
                          You are right, Peter. My mistake. I wasn't even thinking aerosol, probably because I have ZERO talent with spray cans!
                          I read about your process painting the Vincent a couple years ago. I was fascinated. Very impressive results!
                          Dale
                          • painterdale
                            • Oct 2013
                            • 423
                            Originally posted by JTR249 View Post
                            PRG and exeric,
                            Kind regards,
                            -JR
                            Go for it, JR! The worst that could happen is you have to sand it down and start over. Like Eric said, the self satisfaction is definitely worth the effort!
                            Dale
                              • 6029
                              JR, buy a Harbor Freight jamb gun for $35.00, and give it a try. Overall, you may be into it for $150 to start, but you will adapt to the task, and develop your skills, and technique. There are many good paint tutorials on Youtube, and painting really is kind of fun. Don't forget to use a respirator !
