1965 Panhead Tanks
  • panz4ever
    • Mar 2009
    • 197
    1965 Panhead Tanks
    I have asked on this question on another forum (caimag), but am also making the inquiry here as well.
    Is there a template out there for getting the correct location of the color scheme for the 1965 Panhead tanks?
    Going to be starting on my 65 this Fall and trying to get my ducks lined up ahead of time so I do not end up at a stand still with the paint. I would like to use the same painter that did my 49 sheetmetal but to my knowledge he has never done a paint set for 1965 models.
    Any help or leads appreciated.
    • 8213
    Great question, Panz4ever!
    I have two sets in black waiting a few years for the Birch White.
    Problem is mine are 3.5s;
    There are dual 'consensus' for the layout, and I only want to do it twice.
    (Even precise photos would be appreciated, thanks in advance,...)
    • Omarttentmaker
      • Dec 2009
      • 315
      Hey panz4ever.... I have 3 pics of an OP right tank with a seamstress's tape up against it. It's what i used to paint my wife's '65.
      • jwl
        • Dec 2001
        • 338
        The photos you show are of my bike. If you tell me EXACTLY what measurements or photos you need I will try to help if you like.
        • panz4ever
          • Mar 2009
          • 197
          Originally posted by Omarttentmaker View Post
          Hey panz4ever.... I have 3 pics of an OP right tank with a seamstress's tape up against it. It's what i used to paint my wife's '65. [ATTACH=CONFIG]22591[/ATTACH][ATTACH=CONFIG]22591[/ATTACH][ATTACH=CONFIG]22592[/ATTACH][ATTACH=CONFIG]22593[/ATTACH]
          K...good start. Thanks
          jwl, my tanks are 5 gal and it looks like yours in the pics are as well.
          Guess precise pics with the tape will help. Want to be able to duplicate the exact position of the striping (as well as width) and depth of the blue before the lower Birch white panel kicks in.
          Need to be able to see/determine exactly where you positioned your tape (pic block that) in order to correctly loctae the solid top, stripe, and solid bottom.
          • jwl
            • Dec 2001
            • 338
            My tanks, the ones in Cotten's pics, are 3.5. As you can see, the emblem is in the lower color. On 5's, the emblem is in the upper color.
            • Omarttentmaker
              • Dec 2009
              • 315
              The tape starts at the intersection of the bung and the top of the tank.
                • 8213
                JWL!
                Since its all going to be "eyeballed" anyway, I would appreciate just a few level shots from the sides, top, and front.
                (The little thumbnails are futile...)
                And the width of the stripe of course.
                (If its easiest send them to liberty@npoint.net)
                Many thanks!
                PS: I found out the hard way Folks,
                Never lay out tank panels or badges without hanging both tanks on a frame and stand back for perspective.
                • jwl
                  • Dec 2001
                  • 338
                  JWL!
                  Many thanks!
                  Tom, I emailed you 6 pictures in 2 separate emails. Please let me know if you don't get them and I will try again. John Lindemann
                    • 8213
                    Got 'em, John!
                    And I'll share them with whomever wishes...
                    I appreciate that you measured out everything and all, but such close pics are like looking through a telescope.
                    At your convenience (my two paint jobs are already a decade and a half in progress...) it would be great to get a perspective a bit farther away.
                    How did the Factory lay them out, anyway?
                    PS: I'm off to Davenport, so it may be a while before I can digest them.
                    • panz4ever
                      • Mar 2009
                      • 197
                      Updating my thread. Still need the measurement for 5-gal tanks or a template.
                      Called Colorwrite; John Pierce does not have the template.
                      I'd be willing to travel to take the measurements and pics. Frame, swingarm and fenders are out for paint next week, but I can't do squat on the tanks w/o template.
                      • hennigan62
                        • Sep 2010
                        • 140
                        BRIANSCOTT.jpg does this help ?
                          • 5939
                          During my tours of the factory during the '70's, and '80's they were masked freehand. No templates. Just eyeball engineering. They did have a guide for the pin-striping roller they were using in the early '80's.
                            • 8213
                            Thanks Chris!
                            I feel better now.
                            Two sets of 3.5s have been staring back at me for years.
                            PS: These are both from MOCO pics. No two were alike!
                            • panz4ever
                              • Mar 2009
                              • 197
                              Originally posted by HENNIGAN62 View Post
                              [ATTACH=CONFIG]26158[/ATTACH] does this help ?
                              It's a start. Thanks
                              Thanks Chris!
                              I feel better now.
                              Tom that is what I am seeing as well. Your picsare the 2 differences that I have noted in my searching around for 65 tank pics.
                              Thanks. Gives me some options its seems
