Water slide Decals
  • bselph
    • Jun 2009
    • 311
    Water slide Decals
    How do you remove decals that have not been coated without damaging the paint? I put one on my toolbox several years ago and never coated it. It has got some chips in it and I want to replace it and coat this time like I should have to begin with.
    Bob Selph
    1933VC/1934LT Sidecar
    1940 Sport Scout
    AMCA#15215
  • RPjr
    • Dec 2006
    • 57
    High pressure car wash
    • 20scout
      • Dec 2005
      • 238
      Soak it with a wet rag for awhile. Should come off with your fingernail.
      20scout
      • Tom Lovejoy
        • Aug 2006
        • 951
        it is very tricky clear coating over them, good luck
        • 1970 XLCH
          • Nov 2010
          • 177
          If you have clear coat underneath the decal ( which it sounds like you don't ) you can sand the decal off with 2000 grit wet or dry ( do it wet ) . This can also be done with regular plain paint , just cross your fingers you don't go thru . To go over the new decal you need a real fast drying clear . I just did some with "PPG Deltron DC 2000 " ( very expensive about $200 a quart with reducer & hardener ) . A few very light coats with drying over night & very light sanding ( 2000 grit ) in between . then follow up with as many heavier coats as you like . Like Tom said in the last reply" it is very tricky " !! Good luck
          • painterdale
            • Oct 2013
            • 422
            Get your hands on one of those rubber eraser wheels. They are made for removing pinstripe tape. It will buzz it right off.
            Dale
