Transfers
  • msteuer
    Transfers
    Two part question.
    With the 1970s models reaching the 35 year mark has anyone begun to reproduce the "AMF Harley-Davidson transfers" yet ?Seems HD had everything with AMF on it destroyed back when they took back control.
    Question two. I never applied any "varnish" to the water transfer on my "39" for fear or damaging the transfer and or paint. Now that the fuel vapors from the L/H tank have damaged the transfer. I have a replacement set for the next paint job. Any recommendations on brand or technique to seal the new transfer with so that I don't repeat the old problem or create a new one?
    Thanks;
    Mike
  • Paps
    Email Billy at: billywrench@earthlink.net I bet he can help you out. Paps
    • Kojack
      Bill's Custom Cycle seems to have a lot of those AMF era decals.
      Custom Cycle shop that specializes in vintage Harleys. Large selection of parts and an extensive workshop for repair and restoration work. | Bill's Custom Cycles
      Varnish may no longer be the answer for those waterslide decals. Fuels are more volatile than they used to be. I suspect a clear urethane would do better.
      • TOK
        Waterslide transfers
        I'm now in the same position.
        How did it work out.
        Did you brush on the varnish/urathane?
        I assume this is the stuff you get at any hardware store?
        Please advise.
        TOK
