clearcoating over decals ??
  • cscott
    • Oct 2002
    • 451
    trying to apply an indian decal on tanks, and then clearcoat over....problem is the clear area around the lettering remains dull and cloudy while the paint take the shine...i remember 1 restoration i cut each letter out applied them then clearcoated....does anyone know any way to coat these and make the clear area dissapear ? thanks chris
    • 5998
    Chris, are you doing a 1500 wet sanding to the color coat before applying the decal? If so, there will be a noticable dull outline on the decal's boarder when cleared over. On early factory paint jobs, they did all of their finish work before applying the decals, and then used a copal varnish to seal the decal. You will have to apply the decal to a finished surface. Your paint supplier should have a glazing compound that is silicone, and wax free.
    • cscott
      • Oct 2002
      • 451
      thanks eric , i will apply 1 coat of clear than apply the decal then a second coat..thanks
