I have a tank that was sealed before I got it and now it is leaking again. I can easily fix the leaks because they are cracks that can be welded. Naturally the welding will damage the existing sealer and it's obvious that it isn't sealed thoroughly anyway. I'm in no hurry to fix it so I haven't tried anything yet and have never ran into this problem before. I would like to totally remove it, fix the cracks and see if I can get by without having to seal it again. Will paint remover get rid of it or am I going to have to do one of the old rust removal tricks? I would greatly appreciate any suggestions. I don't know what brand sealer it is but it is a medium tan color.
Removing Gas Tank Sealer
Sandblasting comes to mind.Be sure to visit;
I knew someone out there had ran into this same problem before. I'll try to round up some MEK and give it a try. Thanks!
Chris, I would love to be able to sandblast the inside of tanks but how is it done without a microscopic employee and a miniature sandblaster? Do you just manipulate a flexible hose on the end of the gun and hope for the best or is there some other trick? Thanks.
Originally posted by 26modelB View PostI knew someone out there had ran into this same problem before. I'll try to round up some MEK and give it a try. Thanks!
Chris, I would love to be able to sandblast the inside of tanks but how is it done without a microscopic employee and a miniature sandblaster? Do you just manipulate a flexible hose on the end of the gun and hope for the best or is there some other trick? Thanks.Be sure to visit;
