741 'Bitsa'
  • PaulCDF
    • Aug 2019
    • 1434
    741 'Bitsa'
    During the 'pandemic' I began piecing together an Indian 741 'bitsa' this could be labeled "How NOT to build a bike" or perhaps "What I did with my stymie check". I did not document my "process" (or lack thereof) sufficiently. What this is NOT a "restoration" or a "conservation". This is or will be one day an Indian 741 Bobber.
    -I bought an assembled basket case 741 engine and transmission based on: Several discussions with the owner; pictures, Clear title and paperwork.
    -Over time and from various sellers I was able to amass the major parts: front and rear frame sections front girder; front wheel; rear wheel hub; second rim, brakes, seat yoke and handle bars.
    - The frame seller did caution me that the front and rear frame sections; "Are not in the shape I would like" so he was selling.
    FRAME
    -The rear section axle slots had been "buggered" slots into it (for quick wheel
    changes?) I had a bit of luck brazing in some steel to repair the axle slot castings.
    -I started doing mock-ups with the front and rear frame sections bolted together. I put my seat yoke on the frame and found I was sitting 'side saddle'. I was able straighten the seat mount. Next I went to mount the right side oil and gas tank and found only 2 of the 3 tank mounting bolts lined up! On closer inspection I found the neck had been worked on and welded. This repair was beyond my limited skills.
    -I reached out to different folks and got either NO answer or varying opinions ranging from "I would run it like that" to "You need to get that thing fixed or buy a different frame, they make reproduction frames". I have to admit at one point I did think about buying a new reproduction front frame section but then. . . what would happen to this frame?
    - Mr. John Bivens was recommended to me on Virtual Indian forum. I contacted him; we discussed my situation; I emailed some photos. He said he could likely fix it!
    - I shipped the frame sections off.
    PICTURE #1 Show welds on frame and neck
    PICTUREs #2, #3 and #4 Show headstock mis-alignment.
    -The neck 'repair' was crap with a piece of steel crammed into the neck casting to align the tube then welded with extremely poor penetration. Mr. Bivens was able to place the headstock in a shop vice and break it free of the tubes by hand!
    PICTURE #5 Shows Headstock casting separated from tubes
    "The First Rule of Old Motorcycle repair and conservation:
    Someone at sometime in this motorcycles "life" has done something to it which may either injure or kill you. Your job is to find it and fix it before it does."
    741 Buggered Neck Welds AMCA 1.JPG 741 tank frame off AMCA 2.JPG Buggered Neck 741 G VIPC2386 AMCA 3.JPG Buggered Neck 741 H MJZG5887 AMCA 4.JPG Buggered Neck 741 Neck Seperation AMCA 5 NDAU2989.JPG
  • PaulCDF
    • Aug 2019
    • 1434
    PICTURE #1b, 2b and 3b shows the poor penetration of the frame tubes at the headstock. Note oxidation/brown indicates no weld penetration to base metal.
    PICTURE #4b This picture shows DOM tubing Mr. Bivens used to begin repairing headstock.
    PICTURE #5b This Picture shows frame members with a right gas tank on Mr. Bivens jig
    Mr. Bivens he found the rear forks had been 'squeezed' about 1" in from stock. Additionally we discussed tabs and lugs that had been previously removed (perhaps for racing?). As this is NOT a 'Restoration'; points or show bike these tabs and lugs were NOT replaced.
    Buggered Neck 741 j1 BZHW3097 AMCA 1b.JPG Buggered Neck 741 l RSQL9928 AMCA 3b.JPG Buggered Neck 741 k OEAK8478 AMCA 2b.JPG Buggered Neck 741 P QVFJ5137 AMCA 4b.JPG Frame in Mr Bivens shop 1A AMCA 5b.JPG
      • 6039
      Keep it coming, Paul. There is nothing more interesting than a project build thread. I love seeing how people do things and crafts people like John Bivens are ideal to learn from.
        • 1676
        Nice save on that frame Paul! Keep us updated if you can, it's difficult sometimes to pause and take a picture...and then write a little something about it (ask me how I know ) Looking forward to following along!
        • JTR249
          • Jul 2019
          • 768
          Paul,
          Don't feel bad. Almost every 741 front frame section for sale online has some type of repair issue in that general area; either the mast (cross) tube or the neck. When I acquired mine from the UK there was no instrument panel casting to mount anything to and so I had to get one from Ziggy. I'll have to do something similar when I send mine off to be put together.
          I'm still collecting parts for that one! Some of the original parts are very hard to find.
          Good luck and let me know if you need anything. I have a box of spares in storage.
          -JR
          • JoJo357
            • Feb 2016
            • 3306
            Always liked these build threads. Can't wait to see the final product. 'Good Luck' with the 741 Bitsa' Paul.
            *M.A.D.*
            • Green Indian
              • Apr 2014
              • 303
              John’s work is first rate, he’s helped me with the frames and gas tanks on three Indians. Keep the pictures coming!
              AMCA # 3233
