Mick, i love how you are waking your bikes up, servicing everything that had taken them off the road. What is the needle bearing size/number and the sleeve it rolls on?
2 more JD's for the road
Steve Swan
27JD 11090 Restored
27JD 13514 aka "Frank"
Steve,
The inner bearing is a KOYO IR 1612. 1" ID, 1 1/4" OD, 3/4" width
The outer is a INA SCE 202012. 1 1/4" ID, 1 1/2" OD, 3/4" width.
I tried to buy the outer with 2 rubber seals, but couldn't find them in the size I wanted.
One point, do your clutch hub thrust washer with an OEM roller bearing. When it is correct, install the new bearings.
I don't know how this bearing will stand up over time.
Cheers,
Mick
I was getting my 29 ready to start this afternoon.
Connected a remote fuel tank, turned on the fuel and had a nice stream of fuel spraying directly onto the coil.
I figured this is not right, so I checked out the carby.
The float level was very high, so I adjusted that, then filled up the bowl off the bike. Still overflowed, then noticed the float wasn't moving.
I always look at Cottons carby posts as he has a lot more experience with the old carbies than I do. I always was a bit dubious when he would state that some floats don't float. I should have trusted his experience as that is exactly what I found. A brand new float that doesn't float. How can people sell these?
It is a bit hard to see, but this is a horshoe shaped float.
My 29 had a good M1 on it when I got it. I changed it out for a reconditioned DLX 66, which may be correct for a 29JD.
I swapped out an old cork float and got the bike running for the first time in possibly 50 years. The Maine number plate has a label for 1967, so I assume it hasn't been on the road since then.
It won't idle properly yet, I at least need a new float.
Who is selling good floats these days?
Generator is charging nicely at 2-3 amps, converted to two brush. Oil pump is pumping.
I will check the tanks next week to see what condition they are in, then it should be ready for a road test.
I noticed that both tires were not fully seated on the rims, so another job I had to do.
Mick, buy one of Cotten's "DURABLE CARBURETOR FLOATS"!
BRAVISSIMO on your progress!!!!!Steve Swan
27JD 11090 Restored
send him an email - liberty@npoint.net they are $50 bucks with a lifetime guaranteeSteve Swan
27JD 11090 Restored
At your service, right here Mick!
I'm curious; Was your new horseshoe molded?
A molded "elliptical" nitrophyll production is shown balanced by three of mine.
PS: You might save some postage if you can get one from Jim ParkerAttached FilesLast edited by T. Cotten; 06-29-2019, 09:42 AM.AMCA #776
Cotton,
This is my molded float that doesn't float.
I will email you about a replacement.
I fear I would need to see the bottom, Mick!Originally posted by aumick10 View PostCotton,
Cheers[ATTACH=CONFIG]25140[/ATTACH]
The tops of mine look like that, but beneath is machined foam.
I think I see a pivot nut, so its not like some of the heavy India productions where its molded-in.
If you pop out the pivotnut, the float should weigh in the neighborhood of three grams.
....CottenAMCA #776
Cotton,
This is the bottom.
It looks molded to me, you can see the mold lines on it.
Well, Mick,..
If its only three grams you aughta try again.
Although the inferior grades of nitrophyll are doomed in USA fuels to swelling, Scheblers seem to have the clearance to accept it, and your fuels may not yet be P4gas.
....CottenAMCA #776
That's your gas?.. !Originally posted by aumick10 View PostCotton,
I don't have a weight of the float.
The first picture I posted showed the float on the bottom of a canister full of gas.
Yeah, See if Jim will let go of one.
Otherwise, my prices might go up with the trade wars...
....CottenLast edited by T. Cotten; 06-29-2019, 01:54 PM.AMCA #776
