The valves went into the cylinders without incident. George and Mike over at Central Cylinder Service had already put the new guides in and cut the seats for me:
When I went to hang the pistons I found that the bushings were too long. I'd had a local machinist make them for me, and somehow they got made to the proper length for the old pistons, not the new ones. I probably spec'd the wrong length. A minor setback. I made this puller, pulled them out, shortened them on the lathe, and re-fitted them. I found that an original valve spring retainer fit into the end of the perfectly to pull it out:
After that, the pistons went on and the cylinders followed:
Kevin
