1933 Harley-Davidson VL Build: Preparing the Cases
  • panhead_jim
    • Sep 2012
    • 220
    My 1933 Harley-Davidson VL build is finally underway and I'll be cataloging the entire process with step by step articles on Riding Vintage. By the end of this project I hope to have a complete digital archive that someone could use as a blueprint to build their own V-series motorcycle. With that being said, any additional information, corrections, etc would be appreciated to make sure that everything is covered. This first article details how to prep and clean the engine cases before a complete engine rebuild.
    Building a 1933 Harley-Davidson VL: Preparing the Cases
    1964 FLH
    1972 R75/5
    1996 XL1200C
    2001 R1200C
    2007 FXSTB
    Blog: Riding Vintage
    Check out Riding Vintage on Facebook
  • BoschZEV
    • Jul 2012
    • 527
    I hate to write this, and I'm sure not everyone will agree, but I would strongly encourage people not to prep their engine cases the way you did. Yes, bead blasting is fast. But, it removes the original casting marks, which can never be replaced, so the engine will never look like it did when it was made. And, it is exceptionally difficult to remove all the blasting media from the surfaces because some of it embeds itself in the soft aluminum. Subsequent cleaning, wire brushing, etc. will remove some of this embedded Al, but what remains almost certainly won't come out until bathed in hot oil and vibrated by the engine, in which case it will find its way to bushings and bearings.
    • panhead_jim
      • Sep 2012
      • 220
      I agree with you completely that bead blasting is a great way to ruin your engine parts. There are many different kinds of blasting media and choosing the right media for the job is important. For the cases, I used a fine grit aluminum oxide media that is not very aggressive. Still I made sure to move quickly over the parts and not to get the nozzle very close. Before reassembly, every piece will be thoroughly cleaned with compressed air before multiple washings with lacquer thinner and then another dose of compressed air.
      1964 FLH
      1972 R75/5
      1996 XL1200C
      2001 R1200C
      2007 FXSTB
      • sirhrmechanic
        Vigilis
        • Dec 2010
        • 1147
        Hi Jim:
        Lacquer thinner is good for cleaning, but let me suggest hot soapy water, too. Even on steel parts. Water as hot as you can stand on your hands and scrubbing with Dawn or dish soap. That will help a LOT in releasing any particulates from castings. You've probably seen some of my posts on cleaning castings... I prefer not to blast things that contact oil... but it can be done and I only caution anyone who uses media blasting to be scrupulous in their cleaning...
        We go through lacquer thinner (gun cleaner... the cheap thinner) by the 5-gallon pail. It is great stuff. But for cleaning media, there is no substitute for hot soapy water. In fact, our last step before putting pistons in a motor is a bath in hot water for the cylinder block. Using big bore brushes. The bores are immediately wiped and oiled and we have no rusting problems. But we know that even small amounts of grit and oil from the final honing process will get flushed away.
        YMMV, Offer not valid in all states, As seen on TV, etc.
        I should add that I am glad you are doing this... restoration blogs are always great! Thank you for taking the time to post... despite the slings and arrows of us pundits.
        Cheers,
        Sirhr
        • BoschZEV
          • Jul 2012
          • 527
          ...choosing the right media for the job is important. For the cases, I used a fine grit aluminum oxide media that is not very aggressive. Still I made sure to move quickly over the parts and not to get the nozzle very close. Before reassembly, every piece will be thoroughly cleaned with compressed air before multiple washings with lacquer thinner and then another dose of compressed air.
          The fine grit means each grain hitting the Al removes much less metal than if it were larger (i.e. it isn't as aggressive), but the aluminum oxide you used is still every bit as abrasive as it is in larger sizes. It grinds away more slowly, but it grinds away just as inevitably.
          Adding to the woes, Harley cases have a reputation for porosity which means those abrasive grains are trapped in pores below the surface as well as embedded in the surface itself. Unfortunately, multiple washings and compressed air is still going to leave a lot of behind. Compressed air is a bit deceptive because it seems to be doing a lot. However, there is a boundary layer "cushion" at the surface itself that prevents it from removing anything but the loosest particles. The particles that are even slightly embedded (let alone the ones buried in pores) are bound too tightly for the air to do any good.
            • 6039
            How did foundries, or the end user (i.e. H-D, Indian, etc.) remove the sand used in the casting process? I'm a big fan of "How It's Made" on the Science channel and when they show castings being initially cleaned, it's usually with shaking, and media blasting. I would have to believe engine manufacturers were quite sensitive about leftover casting sand, and residue from blasting, if it was used.
            • BoschZEV
              • Jul 2012
              • 527
              I don't know the answer to this question, but odds are that however they did it 80 years ago didn't do much for longevity. Since the bell can't be un-rung on this '33 engine, a very thorough cleaning followed by glyptal (or a more modern equivalent?) to trap as much of the remaining aluminum oxide as possible seems like the way forward.
              • sirhrmechanic
                Vigilis
                • Dec 2010
                • 1147
                Eric:
                You have to remember that casting sand (often green sand... but there are many different types) is a lot different from glass bead or any of the modern media blasting sand. It's hard packed and was also coated with a surface agent. Some kind of a Varnish or maybe a linseed oil... before the casting cores were assembled. That coating both held the sand together slightly, giving it sort of an exoskeleton, and it also gave the castings a smoother surface. If you look at some castings, especially aluminum, you can actually see the brush strokes left by the big-bristled brushes used to apply the surface agent/release agent... whatever it was.
                Often you can see what look like cracks where a core cracked, allowing aluminum to flow into the crack a bit. What can look like a crack in a casting may be just a broken core and as long as the casting could be machined and was structurally sound, the maker was not about to scrap it for a surface flaw. They were building bikes (and cars) to sell at a profit. That meant using things that today we would look at and think... why would they use a bad casting.
                As for cleaning... I can't tell you for sure. Remember, though, that from raw casting to engine, there were also lots of machining steps, coolant being flowed onto the castings, plenty of hands-on... And industrial-strength processes to make sure the castings were clean. Moreover, they had never been exposed to engine oil or age... so arguably the aluminum surfaces were better, smoother and less- subject to retaining embedded crap. That said, on a couple of occasions, we have been cleaning out Rolls-Royce crankcases and 'poked' a screwdriver or a pick into a fissure or casting bubble and been rewarded with oil-soaked casting sand. It did stay there!
                So that's a long way of saying... I don't know for sure. Suffice to say in modern times, we should all know what needs to be done and those who learned expensive lessons can teach those who have yet to learn them. That's the value of communities like this. But Woe-betide the engine builder who cuts that particular corner. Sand and oil don't play well together.
                Cheers,
                Sirhr
                • BigLakeBob
                  • 2768
                  Cheers,
                  Sirhr[/QUOTE]
                  I'm sure I am not alone. All I have ever seen in shops that rebuild HD engines is a glass bead cabinet that was most always used in preparing the cases for a rebuild. My short time in this hobby is 30 yrs, and of the 3 states I have lived in during that time that is the practice of every shop I've been in including HD dealerships. I don't know of one engine problem I have had. I do it myself now. Don't get me wrong, I believe cleaning is essential, but are you guys now saying that this is a wrong practice that needs to be stopped for future engine builders? Bob#6738
                  Bob Rice #6738
                  • billpedalino
                    • Mar 2005
                    • 1096
                    I agree with BigLakeBob.
                    I worked in a relatively high-production Harley motor and transmission shop on Long Island for many years and we glass beaded everything with a large Zero Blast-N-Peen machine. While I do agree that the caution that some of you issue is certainly well-founded, I respectfully differ with the ability to effectively and adequately remove the media provided that you do the work to do so.
                    We hot-washed the cases repeatedly and scrubbed them well. We did not (for the most case) use Gasoila or Glyptal and we stood fully behind all of the motors and transmissions that we turned out. And this was in the 1960's and early 1970's so there were a lot of them! Most of these machine Owners remained customers for well over a decade after their rebuild and in most cases we performed routing repairs and service on their machines well after we rebuilt their motors. In all that time I have never experienced any problem resulting from glass bead being released into the oil after assembly.
                    Now that my motor building is limited to my own machines and a couple of close friends only, I continue to glass bead cases (when necessary) and thoroughly clean them with no ill effects unless I can adequately clean them without abrasive blasting. As an Engineer I know how easy it is to theorize about what might happen, but at this point I've been doing this for over 40 years, so I must stand by my experience.
                    However, I have started using Glyptal recently and I can't really say why. I guess it's just nostalgic in that I like the way it looks and it reminds me of how the cases used to look when I was young and I was the mechanic fortunate enough to be taking a set of cases apart for one of their first rebuilds. But I do concur with my colleagues above, if you don't do the meticulous and arduous work in cleaning the glass beads out you will be running a time bomb of a motor.
                    Bill Pedalino
                    Huntington, New York
                    AMCA 6755
                    • BoschZEV
                      • Jul 2012
                      • 527
                      The following report says the contrary:
                      Ihr Flugpreisvergleich von Linienflügen, Gabelflügen, Charterflügen und Multistopp-Flügen mit dem Waschbären. Die Tarife für Billigflüge werden täglich aktualisiert, dadurch können wir Ihnen immer die neusten Angebote zu Verfügung stellen. Buchen Sie Ihre Urlaubs- oder Businiesssflüge in nur 3 Schritten online auf unserem Billigflug-Portal. Sollten Sie einmal auf unserer Internetseite nicht fündig werden, stehen wir Ihnen mit unserem Serviceteam mit internen Billigflug-Angeboten jederzeit gerne zur Verfügung.
                      Most engine overhaulers or repairers have experienced problems related to glass beads. However, many were never aware of the root cause for their problems, and either gave up on the search for a cause or attributed the cause to something else. This is because glass beads will defy cleaning efforts and are difficult to identify after the damage is done.
                      Ball bearings typically have service lifetimes 10x shorter than they should have. Clearances are tight so even a tiny defect introduced into the race or a ball has significant consequences. A few stray glass beads are sufficient to cause such defects. If a bearing starts going bad after 10,000 miles how many workers in a rebuilding shop would disassemble that bearing and spend a very long time peering through a microscope trying to identify the root cause of that premature failure? How many instead would simply assume the manufacturer had shipped a defective bearing?
                      Aluminum oxide is an insidious killer of engines. However, instead of a smoking gun, it leaves fingerprints very few people are even equipped to look for. The issue is you know having aluminum oxide particles in an engine is bad. It's 9 on the Mohs scale of hardness, whereas hardened steel is only 7 or 8 (and a bronze bushing only 3). What you're relying on is faith that somehow you have been able to completely clean it from all surfaces.
                      Yes, that's what I'm saying.
                      • harleytoprock
                        • Apr 2003
                        • 374
                        Glass beading must be done with caution and precautions. First the case must be completly oil free. Threaded holes must be pluged and any oil passages also. Race surfaces must be masked. Then super cleaning must be done after. I bet anyone who has had problems with glass beading didn't start with oil free cases and then just blew some air after beading to remove the dust. A set of freshly glassbeaded panhead heads was brought me to have the seats cut and to assemble. Upon closer inspection I discovered that the oil passages were so packed with oily glass beads, I had to drill them out. After much super cleaning the heads were fine.
                        Aluminum oxide, course or fine, is really bad because it will imbed into the metal much worse than glass beads. Glass beads are round and should bounce off the surface.
                        • sirhrmechanic
                          Vigilis
                          • Dec 2010
                          • 1147
                          And just to throw in my 2 cents of a dollar...
                          Bead blasting has its plusses and minuses. Plus is it's fast and scours well. Minuses are that it requires scrupulous clean-up. It's not that it should not be used... but it should be, as Toprock says, with caution and diligence. You can get a lot done in a hurry with it. You can also get yourself in trouble...
                          But the same is true with anything... Torches, hammers, vice-grips and adjustable wrenches are all miracle tools in the right hands and implements of destruction.
                          Make your choices but do it knowing that there are no shortcuts... fast bead blasting means slow, meticulous cleaning. Slow meticulous cleaning of castings with solvents and Scotchbrite negates some of the challenges of cleaning bead but is slow as hell and bad for my manicure. Glass half full... glass half empty... glass designed 50% too large. Take your pick.
                          The main thing we should get across is to use your available tools right... and like golf clubs there is one for every possible shot. You can try a 400 yard drive with a putter, but why would you use a putter if you have a 2 wood. (Man, you would think I played golf... I refuse to spend my time hitting a ball in a hole when there are bikes to play with... but it was a great analogy!)
                          Back to the OP... keep up the great posts on your VL! That's what I'm most interested in.
                          Cheers,
                          Sirhr
                          • BigLakeBob
                            • 2768
                            Jim, thanks for the thread and I wish you the best with your journey.
                            With all the unfiltered air cleaners on the early bikes maybe the Cannonball should start further north, I mean a grain of sand may make it in the carb, past the valve through the rings and destroy the bearings before they make it out of the state. I appreciate what you are saying but maybe a little overboard. I think proper cleaning is the key. Ever put oil in a bike in Florida? Ever take off the oil fill on a tranny in Florida? It is very hard to get rid of all the sand/oil mix around the plug first, so sand is going to get in there, we live in a world of contaminants. How hard is the carbon formed on the piston on the Scale you mentioned? I'm not trying to be facetious but I think we are getting too technical here. Bob #6738
                            Bob Rice #6738
                            • BoschZEV
                              • Jul 2012
                              • 527
                              Carbon black, the form that is probably closest to what's on a piston, is only ~2.5, i.e. it's softer than the bronze bushings.
                              Hey, all I can do is point out a problem, explain why it is a problem, and provide references to support what I've written. It's up to each person to decide whether or not to act on that information. It's certainly easier -- at least in the short run -- to ignore it.
